» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 06-18-2009, 07:31 PM   #11 (permalink)
mitaka's Avatar
oh trust me there are many other ways to stop a diesel. cam sensors when they get overheated etc., my pump was fine and I got stuck three times...They never figured out my problem exactly...that's wh I am driving R350 now
09 R350 P1, Capri Blue, Panorama Roof, iPod, Rear Seat Entertainment System, Heated Front Seats
Previous cars:
07 R320 CDI
Audi A8 4.2 Quattro
Audi A4 1.8T Quattro
VW Passat 4 Motion
05 Dodge Durango HEMI
mitaka is offline   Reply With Quote
Old 06-19-2009, 04:08 PM   #12 (permalink)
Date registered: Nov 2006
Send a message via Skype™ to Wayne Wu
Well, after a week of triaging by the mechanics as well as back and forth with their German head office, as expected, they said it is the fuel pump. As such, they put in a new one and that is the end of the story.
The take away on this is, who the hell designed and manufactured this pump? The failure rate is way too high and it is not fault prove or tolerant. This piece is mission critical and I expect a premium piece since I paid premium price for the R Class CDI.
Here is what I learn from this incident when a diesel engine stalls ...
#1. Fuel pump relay heating up and failing.
#2. Ignition coil heating up and failing.
#3. Fuel pump failing.
Need fuel pressure monitored until it fails. Check resistance of ignition coil.
LOL
Wayne Wu is offline   Reply With Quote
Old 06-26-2009, 01:36 PM   #13 (permalink)
Date registered: Jun 2009
Question ignition coil?
on a diesel?
what function does that have?
willyjp is offline   Reply With Quote
Old 07-01-2009, 09:22 PM   #14 (permalink)
BTW, they claimed they changed both fuel pumps both the small one in the gas tank and the high pressure one. No problem yet, so far ...
Diesel engine does not have a spark plug but a glow plug which you need some kind of coil for induction heating.
Old 07-03-2009, 07:09 PM   #15 (permalink)
Wyatt_Earp's Avatar
Date registered: Mar 2009
Mikata and others:
Diesels generaelly don't stop without 1 of two things. 1, lack of air or 2 lack of fuel. So, breaking that down and not knowing exactly what transpired at the shop for $800 it would seem that you are suffering from common air in the injection pump.
If anything fuel related, including a fuel filter was changed in that service you can stall the car very easily with air bubbles in the IP either during start up (after the filter change) or upwards of 60 minutes after. This isn't much to worry about and is a simple fix.
This is not to say that it couldn't be something else but unless there is a code thrown it is doubtful that the CPS or TPS or even the rail pressure sensor is out of range causing a cascading effect of falling on its face dead.
If a crank position sensor is faulty you would first witness hard starts, poor mileage and even some smoke under hard accleration. If the rail pressure sensor is out of range from a malfunction or a tuning box perhaps, the car would knock, surge under cruise control and generally act funny. This is common in the case of poor computer hacks that sell you a plug and play box that adds too much fuel and raises the rail pressure beyond 27,000 psi. Assuming that is not the case then it is also unlikely that it would be the TPS (throttle position sensor) since this is controlled by the ECM which unless fooled somehow is generally bullet proof unless the IP is going out on you which I find a really tough sell on a BENZ.
So, my experience would tell me that it is just a little air in the high pressure fuel system (ie between the injection pump or IP and the injectors themselves).
This can easily be solved by purging the air from the fuel filter, the inlet to the IP (be careful not to do anything on the HP side as it can seriously hurt you!!) or even the HP lines to the injectors themselves.
More often than not anything other than purging the air from the filter should be done by someone who is qualified or at least has some diesel know how.
Wyatt Earp
2008 R320 CDI - Diesel Luxury
2003 VW Golf TDI GLS 5spd, AFE Stage 1, Timing bumped, Sitting on Yoko 225/17 and Eagle Rims with lots of go for cheap
2002 Dodge 2500 Cummins Diesel LWB, 4x4, SLT, Quad Cab, 6spd, 2" LVL kit, DSS, Stage 5 sticks, AFE stage 2, ATS Manifolds, Smarty Box, Comp Box, Trailer Brakes, Custom lights and switches, FP, Boost and Pyro gauges, Ring MIA, Sitting on 33" Toyo MT's
Save the Planet, Drive an Oil Burner
Wyatt_Earp is offline   Reply With Quote
Old 07-03-2009, 07:26 PM   #16 (permalink)
Wyatt_Earp's Avatar
What you are describing here is something that I haven't ever seen on a modern comon rail diesel that is un-modified. The in-tank lift pump (it isn't a fuel pump) is designed to push fuel to the high pressure or injection pump. If you had crap in the tank you can get the inlet screen plugged and cause the injection pump to burn out under the heat of having no fuel to lubricate itself with. Seems simply enough right? Well it is and it isn't. The high pressure side is designed by bosch if I'm not mistaken and is generally regarded as the best in the business for the common rail application.
Although I don't know what the exact pressure is at the IP it can be easily tested and would be somewhere south of 11 psi I would think. On the high pressure side it would be as discussed around 24,000 to 26,000 psi or so.
The most common failure beyond having the in-tank pump plug and die would be to have a poor quality or too high a micron rated fuel filter in the OEM canister. Again, it would be important to determine what the specification on the micron rating is but if it is finer (higher) then 6um you will run into problems on even ULSD if this is the primary filter. As say with a 3 um the filter will plug too fast resulting in little fuel travelling to the IP which makes the unit heatup and break apart from the inside.
If this remains a problem, rigging up a primary and secondary filter system would fix most of it. This can be done with a 12um or a 10um as primary and a 6 or a 3 as the secondary. I would also suggest that changing them more often, at say every oil change, is better than what the book or shop would tell you. Filters are cheap in comparision to pumps as you have found out.
In addition to all of this you can easily build a pressure gauge, complete with isolator and snub valve to read pressure in the cab while you boot down the 401. This would cost around $120 to $170 and is easily obtainable from any truck shop or diesel performance shop that carries ISSPRO gauges. The trouble is that you'd need to find a place to put it in the cab. Buying a cup holder for it is likely not an option since few people would do this to a benz but you could have one built out of fibreglass.
Let me know what you find out. I'm interested to know what the results are.
Old 07-03-2009, 10:50 PM   #17 (permalink)
mitaka's Avatar
Originally Posted by Wyatt_Earp View Post
Mikata and others:
Never witnessed any of the above such as hard starts, poor mileage or smoke with my CDI and yet the crank position sensors kept giving me problems. The car was running great. After normal operation the crank position sensor will overheat and and the car won't start. Engine will crank but wont start. After 30-40 min after the car had cooled off it stared as if as there was nothing wrong with it...
Old 07-04-2009, 07:36 AM   #18 (permalink)
Wyatt_Earp's Avatar
Well, a CPS unless faulty from the factory can't cause it to stall. It would cause it to not start because it wouldn't know where TDC is but otherwise, I would suspect you had other problems.
When you cool it down as indicated and it starts fine that is a fueling problem - very common from Dodge, VW, GMC and even big class 8 trucks. The IP doesn't like to be warm and under a hard start condition like that it isn't getting any or enough fuel and it goes into protection mode and shuts down. This could, although unlikely cause what would appear as a fault TDC reading on the CPS due only to the hard start from lack of fuel.
Old 07-04-2009, 08:38 AM   #19 (permalink)
AsianBlackR350's Avatar
Date registered: May 2008
After reading all these threads about Diesel engine problems, I am so glad that I purchased R350 gas engine which is quieter, cleaner, faster compare to R320 and have no problem so far. Gas mileage is not an issue for me.
I have to admit diesel engine last longer than gasoline engine and the torque in R320 is great for towing but I do not tow any boat or others so no need for me.
2008 R350 4 Matic w/P1 package/7 seater/Ipod/Front heated seats/ Retrofitted OEM GPS Navigation / 10.2" LCD Overhead Mobile Video system w/ 30 Sega Games, Wireless HeadPhone, hard wired to OEM HK sound system, B/U Camera integrated W/ 6 Disc DVD Changer , hard wired Passort Escort X8500, Mtec HID, 17 SMD LEDs city lights.
2007 Acura RL w/ tech package, A-spec body kit, Deck lid spoiler,TVandNAV2go,USA spec Audio, 18 " Wheels, Wooden steering wheel, Wooden shift knob
AsianBlackR350 is online now   Reply With Quote
Old 07-04-2009, 03:17 PM   #20 (permalink)
Wyatt_Earp's Avatar
See, I completely 100% disagree. Diesel is cleaner, more fuel effecient and delivers far better return on investment then a gasser. The reason why more than 60% of new cars and trucks on the road in other countries are diesel is that they outlast all others.
Granted there are a few things that are very different with an oil burner than a gasser but once you educate yourself on those items and know what to look out for then it is pretty much a breeze. The problem in the US and CND is that there are generally few specifically trained diesel technicians in the dealerships and this makes things difficult at times. Especially if you are trouble shooting something as described here.
I'm glad you are happy with your gasser but I'll keep all of my diesels... Cheers,
R320 CDI - First Merc! russ1974 New Member Introductions 1 03-26-2009 02:09 PM
Looking to Buy Used R320 CDI Rancher W251 R-Class 1 03-15-2008 05:15 AM
R320 CDI Mpg? flw210 W251 R-Class 15 12-06-2007 10:57 PM
R320 CDI Prices? TomPuorro W251 R-Class 6 04-11-2007 07:03 PM
R320 Cdi djw W251 R-Class 1 08-22-2006 09:32 PM
