» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 05-18-2009, 05:22 AM   #1 (permalink)
eric242340's Avatar
Vehicle: S320 and Zotye 1.3
Send a message via Skype™ to eric242340
R251 Suspension problem
This one should prove to be interesting.
About this time last year the workshop was packed with W220 and the known Airmatic problems. We did not see one R251 with a suspension problem. I thought Benz had, at long last, put this issue to sleep.
Wrong, tonight before I finish work in limped a R251 with the right rear on the floor and the Airmatic pump making more noise than the engine eek.
No further details as yet, will keep you informed in the morning.
ERIC.
What a day! Hoovering, dusting, polishing – how's a man supposed to nap when his wife's doing all that?
Andy Capp
eric242340 is online now   Reply With Quote
Old 05-18-2009, 01:38 PM   #2 (permalink)
Date registered: Mar 2003
Please keep us posted, I am close to buying a W251. Do all the W251s have this pump? This is not a pump for the Airmatic option right?
cyeung65 is offline   Reply With Quote
Old 05-19-2009, 05:06 AM   #3 (permalink)
eric242340's Avatar
Airmatic and associated problems on W251 R Class
Please re read the first post.
Old 05-19-2009, 05:16 AM   #4 (permalink)
eric242340's Avatar
OK, I have just repaired this W251 4 matic, the car had 92000 km on clock.
Parts changed
1 x Airmatic Pump
1 x Airmatic Relay
1 x Airmatic plastic valve distribution block
Now most of you know I am a manager of a specialist workshop and not in any way connected to the Dealership. I did say this was the first R Class I had seen with the Airmatic problem.
So today I phoned my friend who is the manager over at the Dealers and he shocked me. In his words the R Class has just as many Airmatic issues as the W220 and W221.
Good news is that the Airmatic issues with the W251 normally happen during the warranty stage and that is why I had not seen many of them in my workshop
So if you are thinking of buying one do not be put off by the long running Airmatic saga.
Old 05-20-2009, 08:15 AM   #5 (permalink)
Date registered: Apr 2008
Vehicle: '06 R350
I don't recall seeing any posts on here in the past concerning Airmatic issues w/ the W251... I'd think that if is was as pervasive as that shop manager indicates, we'd see more talk of it here. (BTW, no issues for me thru 35k mi.)
mroadster is offline   Reply With Quote
Old 05-20-2009, 08:23 AM   #6 (permalink)
eric242340's Avatar
Simply because you have no problems and there have been no posts on this problem before does not mean the problem does not exist. But I did say it is not something to worry about, simply to be aware of
Old 05-20-2009, 09:30 AM   #7 (permalink)
Wyatt_Earp's Avatar
Date registered: Mar 2009
Interesting. How easy of a fix was that? Basic tools and a set of jack stands or is this a big deal?
Wyatt Earp
2008 R320 CDI - Diesel Luxury
2003 VW Golf TDI GLS 5spd, AFE Stage 1, Timing bumped, Sitting on Yoko 225/17 and Eagle Rims with lots of go for cheap
2002 Dodge 2500 Cummins Diesel LWB, 4x4, SLT, Quad Cab, 6spd, 2" LVL kit, DSS, Stage 5 sticks, AFE stage 2, ATS Manifolds, Smarty Box, Comp Box, Trailer Brakes, Custom lights and switches, FP, Boost and Pyro gauges, Ring MIA, Sitting on 33" Toyo MT's
Save the Planet, Drive an Oil Burner
Wyatt_Earp is offline   Reply With Quote
Old 05-20-2009, 09:36 AM   #8 (permalink)
eric242340's Avatar
Get a job in a Benz workshop then find out
Old 05-20-2009, 09:47 AM   #9 (permalink)
Wyatt_Earp's Avatar
Yeah, no thanks. I just like to fix things myself if I can. I don't have the problem but if I did - it would be nice to know it could be done.
Old 05-20-2009, 09:56 AM   #10 (permalink)
eric242340's Avatar
Trust me, if you did have this problem I would help you to DIY it
R251 DIY GermanStar W251 R-Class 9 09-24-2009 05:20 AM
Suspension Problem namgets W126 S,SE,SEC,SEL,SD,SDL Class 0 04-14-2009 07:09 PM
suspension problem uk_ducati V-Class 2 02-24-2009 02:28 PM
i need some help!!!! i have a suspension problem. seyhap W220 S-Class 2 11-06-2006 09:20 AM
S600 Suspension Problem & braking problem Guest (MBNZ) W140 S-Class 1 02-07-2002 03:25 PM
