» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 08-06-2009, 07:37 PM   #21 (permalink)
Date registered: Dec 2008
Dealer Warranty Fix(?) for Airmatic
Originally Posted by rennerlko View Post
I have an R500 with 30K and it will raise and lower by itself- once when the passenger door was opened, once when at a stop light. Seems the right side sits aboiut 1.5 inches higher than the left, as measured above the real wheels to the edge of the wheel wells.
The dealership had the vehicle for 3.5 days (for a full plate of warranty repairs/adjustments) and this is what the fix was for the Airmatic issue:
"Recalibrated the vehicle level on the alignment rack with the Romess gauge".
Without giving all the specific level measurements and recheck measurements in CM, it was turned over to me as corrected on Thursday last.
Today I noticed the issue is back with the right rear being obviously higher, just by eysight, than the left.
Hummmm....they checked the tire air pressures, they aligned the vehcle, made the measurements good, found no codes or faults onboard.
I'm at a loss.
rennerlko is offline   Reply With Quote
Old 08-07-2009, 05:27 AM   #22 (permalink)
eric242340's Avatar
Vehicle: S320 and Zotye 1.3
Send a message via Skype™ to eric242340
Possibly a faulty valve block, this is located above the pump.
ERIC.
Tree of Life' remains a valid metaphor for much of the historical process of evolution.
eric242340 is online now   Reply With Quote
R251 DIY GermanStar W251 R-Class 9 09-24-2009 05:20 AM
Suspension Problem namgets W126 S,SE,SEC,SEL,SD,SDL Class 0 04-14-2009 07:09 PM
suspension problem uk_ducati V-Class 2 02-24-2009 02:28 PM
i need some help!!!! i have a suspension problem. seyhap W220 S-Class 2 11-06-2006 09:20 AM
S600 Suspension Problem & braking problem Guest (MBNZ) W140 S-Class 1 02-07-2002 03:25 PM
