» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 05-20-2009, 10:12 AM   #11 (permalink)
Wyatt_Earp's Avatar
Date registered: Mar 2009
It's a date then. I don't have it yet but you never know. I have about all the tools one would need, along with jacks, the STAR DVD and other such goodies. I don't own a lift but that's ok.
I've done lots of diesel work, repair, mostly in engine work and know how to make them go fast so I can be dangerous for sure.
Wyatt Earp
2008 R320 CDI - Diesel Luxury
2003 VW Golf TDI GLS 5spd, AFE Stage 1, Timing bumped, Sitting on Yoko 225/17 and Eagle Rims with lots of go for cheap
2002 Dodge 2500 Cummins Diesel LWB, 4x4, SLT, Quad Cab, 6spd, 2" LVL kit, DSS, Stage 5 sticks, AFE stage 2, ATS Manifolds, Smarty Box, Comp Box, Trailer Brakes, Custom lights and switches, FP, Boost and Pyro gauges, Ring MIA, Sitting on 33" Toyo MT's
Save the Planet, Drive an Oil Burner
Wyatt_Earp is offline   Reply With Quote
Old 05-20-2009, 03:40 PM   #12 (permalink)
Date registered: Apr 2008
Vehicle: '06 R350
Originally Posted by eric242340 View Post
Simply because you have no problems and there have been no posts on this problem before does not mean the problem does not exist. But I did say it is not something to worry about, simply to be aware of
Yeah, but like old people with medical issues, usually even the most minor matter affecting the smallest number of people gets discussed around here. With something as significant as the air suspension, I would have thought someone would have made as post about it before now. In any event, all my rambling about it should ensure some bad karma and I'll start having suspension issues any minute.....
mroadster is offline   Reply With Quote
Old 06-30-2009, 09:02 PM   #13 (permalink)
Date registered: Mar 2008
Eric,
I have an '06 R-500 with 10K on it that has the airmatic system. I also have an '04 E-320 wagon with the same. The wagon had a "problem?" with the pump wire being stretched and losing power to the pump(easy fix in the driver's wheel well). The R has this weird err, err, err noise coming from the driver's rear when ever a door is opened, especially if the vehicle has been sitting idle. Is this the ride control pump that I am hearing? There have been no codes or ride issues unlike the wagon that just snapped a front coil spring at 70K and the sway bar links are junk!
skigyz is offline   Reply With Quote
Old 07-01-2009, 02:17 AM   #14 (permalink)
eric242340's Avatar
Vehicle: S320 and Zotye 1.3
Send a message via Skype™ to eric242340
Originally Posted by skigyz View Post
Eric,
Not sure what it is that you can hear but it is not the airmatic pump. The pump is behind the front fender on the passengers side.
ERIC.
Tree of Life' remains a valid metaphor for much of the historical process of evolution.
eric242340 is offline   Reply With Quote
Old 07-02-2009, 12:59 PM   #15 (permalink)
Date registered: Jan 2008
Vehicle: 88 300sel, 99 c230k, 07 r350
I recently have this issue on my 07 r350. Currently is in the dealer for the 3rd time. Two weeks ago I took it in for my right rear suspension is completely down to the ground and dealer replaced the strut. I came home and the same problem so I took it back in and they replaced the distribution block. Got it back and the same issue. I talk to the dealer's GM and promised me they will not give the car back until the issue is gone.
onlymb is offline   Reply With Quote
Old 07-02-2009, 08:18 PM   #16 (permalink)
Thumbs up
Let me add to the airmatic pump issue. Mine was replaced this week while under warranty. I have 20K miles on the clock. I have an '07 CPO R350. Other than that issue, the wife and I have been very pleased with the R251. I would recommend it to my friends. Besides, the car has an identity of it's own.
MovingOnUp is offline   Reply With Quote
Old 07-14-2009, 11:38 PM   #17 (permalink)
Date registered: Dec 2008
I have an R500 with 30K and it will raise and lower by itself- once when the passenger door was opened, once when at a stop light. Seems the right side sits aboiut 1.5 inches higher than the left, as measured above the real wheels to the edge of the wheel wells.
rennerlko is offline   Reply With Quote
Old 07-21-2009, 07:21 PM   #18 (permalink)
Date registered: Apr 2009
Vehicle: 2007 R-350
I have an 2007 R-350 with 47000 miles,and i get airmatic issue.they will repair with no cost at the dealer?
LEME is offline   Reply With Quote
Old 08-06-2009, 09:42 AM   #19 (permalink)
Wyatt_Earp's Avatar
Trust me, if you did have this problem I would help you to DIY it
Eric,
Well I might just take you up on that. We've been taking some long trips in the new car lately and yesterday my wife was driving home with the guests in the car I sat in the back left seat (not 3rd row) and the car made some aweful noises running over a few bumps on the road. In fact some hit really hard - too hard for something that i supposed to run as smooth as it has up till now.
This may be a problem.
It needs its first service here soon so I may take it in under warranty but that may prove a lengthy process.
Anyway, any input would be appreciated.
Old 08-06-2009, 10:01 AM   #20 (permalink)
eric242340's Avatar
Originally Posted by Wyatt_Earp View Post
Eric,
Warranty is the way to go just now, and let us know how you get on thanks
R251 DIY GermanStar W251 R-Class 9 09-24-2009 05:20 AM
Suspension Problem namgets W126 S,SE,SEC,SEL,SD,SDL Class 0 04-14-2009 07:09 PM
suspension problem uk_ducati V-Class 2 02-24-2009 02:28 PM
i need some help!!!! i have a suspension problem. seyhap W220 S-Class 2 11-06-2006 09:20 AM
S600 Suspension Problem & braking problem Guest (MBNZ) W140 S-Class 1 02-07-2002 03:25 PM
