With some help from this thread Telematic Info I finally finished this retrofit. Mine came with Tele-aid and pre-wire for cell phone.
Here is the outline of what I did. I will go into more details in followup posts.
What you need to buy:
1. Vehicle core kit; including MHI (ie. UHI) and linear compensator.
2. Vehicle completer kit for R-class.
3. Bluetooth dongle, either MB OEM or ViseeO MB-2.
What you need to do to install:
1. Remove/install right side 2nd row and front seats and lining underneath to get access to footwell that MHI mounts into. It took me 2 hours.
2. Remove/install spare tire mount to mount linear compensator. Took 30 minutes.
3. Remove/install driver seat and lining underneath to change optical wiring for amplifier if you have premium sound system as I do. Took 45 minutes.
4. Remove/install front passenger right side footwell panel to change optical fiber wiring. Took 20 minutes.
Star tool configuration:
1. Select retrofit MOST modules and reset the MOST circle. This allows the telematic unit be recognized by COMMAND unit.
2. Set up microphone. Mine is an older mirror type with 4 microphones.
3. Set tele-aid primary and secondary antenna resistance to <1 ohm to avoid error message.
4. SRS warning will pop up since you removed the seats. Do quick scan and clear error codes to get rid of the message. If everything is installed correctly, you should not see any error message after another quick system scan.
Now all you need to do is plug in the bluetooth dongle and pair/sync with your phone and car. Mission accomplished.:thumbsup:
Pictures:
1. Telematic!
2. ViseeO MB-2 bluetooth
3. Old style mirror that has 4 microphones.
4. Part numbers
5. Vehicle Core Kit
Pictures:
1. Telematic!
4. Part numbers
5. Vehicle Core Kit
