yaw rate sensor location - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-28-2009, 03:05 PM Thread Starter
Date registered: Jan 2009
Hi,
1.Does anyone know where the yaw rate sensor is located on an R320 CDI? and also the part number.
2.I'm getting a tyre pressure fault showing, could this be due to changing the rims to 20"?
Thanks
Franco
RKLASSE is offline
post #2 of 7 (permalink) Old 02-28-2009, 04:41 PM
Date registered: Sep 2008
Vehicle: 2006 R500 Red w/Tan interior
Yaw rate and lateral acceleration sensor is located under the front passenger carpet and subsequent floor board. Since you changed out wheels, I would start there. I would reccomend having MB hook your vehicle up to STAR system and see if there are any faults. The Yaw Rate piece is located bottom left of the floorboard oriented when you are sitting in the front passenger seat.
rgood10921 is offline
post #3 of 7 (permalink) Old 02-28-2009, 11:58 PM Thread Starter
As my car is a UK model (Right hand drive) I presume that means mine will be under the driver's seat?
Franco
RKLASSE is offline
post #4 of 7 (permalink) Old 03-01-2009, 10:11 AM
That would be my assumption, the sensor would still be under the passenger side. But, I am not positive about that though. My Star DVD does not mention the right hand drive, thus I can't confirm for you.
post #5 of 7 (permalink) Old 03-02-2009, 09:47 AM
chucelli's Avatar
Date registered: Aug 2006
Vehicle: 2000 E430 4Matic, 2007 R320 CDI, 2012 E63 P30, 2013 SLK250
Quoted: 12 Post(s)
If you don't have pressure monitors in your 20s, your tire pressure display will fault.
chucelli is offline
post #6 of 7 (permalink) Old 03-05-2009, 06:04 AM
Date registered: Mar 2009
Vehicle: 2008 R320 CDI formerly 1999 ML430
This does not address yaw but I had a problem with TPMS (tire pressure monitor system) illuminating red warning lamp. Repeated adjustment of tire pressures and resetting alarm would not resolve problem. Also radio would spontaneously cancel mute.
2008 R320 CDI, original 18 inch wheels and Continental tires with 2604 miles
Mercedes of Colorado Springs January 29 trouble ticket showed cause:
"2604 glow plug control module perform short test found fault codes in the TPC module and COMMAND for overvoltage the [sic] has turned on the warning light and caused mute on radio complaint."
This diagnosis and repair made trouble go away and I haven't had difficulty since. Fortunately the repair was under warranty. Service writer told me cost would be $800 - 900.
bileve is offline
post #7 of 7 (permalink) Old 03-15-2009, 02:49 PM Thread Starter
Thaks guys, I have now replaced the yaw sensor and Esp is now working fine.
Franco
RKLASSE is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
    Yaw Rate Sensor and ESP/BAS light Dting22 W163 M-Class 150 04-06-2016 12:28 AM
    '98 A160 - $8000 for a yaw rate sensor in Oz??? RobCox W168 A-Class 6 04-04-2008 07:42 PM
    C1120 N64 ESP yaw rate sensor.zero point offset error of component jrkong W203 C32 AMG, C55 AMG 2 03-11-2008 06:42 PM
    99 ML430 YAW Rate Sensor mlCharlie W163 M-Class 1 09-22-2006 02:49 PM
    Yaw rate sensor - 1998 C280 aes1128 W202 C-Class 1 07-05-2004 11:44 AM
