Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 08-05-2008, 05:11 AM   #1 (permalink)
Date registered: Feb 2008
Question About DRL's and other ecu mods
Have any here on the forum tried to mod the ECU or what ever MB is calling it?
On my VW and Audi cars I used vagCom, to modify the settings in the car e.g. I set the front fogs as DRL's and setup up thr DRL's with the rear light as well, makes more sense... I konw the CAR has auto head lights but in soem contries the front and rear lights must be on all the time the engine is on.
Also it could be nice to deactivate the cornering fogs and install a hid hit in the front fogs to match the front lights
Adjust the rain sensor as right now it is set for old men, full speed with little rain, many times i skip the rain sensor and then uses the normal wipers, even it has 2 settings for the sensor, they are both too sensitive. I tried to get the dealer to adjust, but no change...
Any input appreciated
2008R320 is offline   Reply With Quote
Old 08-05-2008, 08:21 PM   #2 (permalink)
nanoera's Avatar
Date registered: Jul 2008
I too jumped boat from VAG. Already miss my VAG-COM power.
I hope they come up with some BIMM-COM or BENZ-COM asap.
For resetting service interval you can use instrument cluster. I am not sure how powerful the cluster goes.
'06 R350
nanoera is offline   Reply With Quote
ECU dahappybanana W163 M-Class 3 03-12-2008 06:45 AM
How to Disable DRL's? Substance W163 M-Class 1 10-02-2007 01:51 PM
290gd turbo ecu mod and or other mods 290gdt G-Class 6 12-21-2006 04:50 AM
I did a search regarding DRL's... asianml W163 M-Class 17 10-10-2005 05:48 PM
If mods done , ECU reset needed? Guest (MBNZ) W202 C-Class 0 05-15-2002 06:56 AM
