Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 06-12-2008, 11:48 PM   #1 (permalink)
Date registered: Jan 2008
how much oil
How much oil does the R500 take. I read somewhere where someone put in 9 qts. Does it only take 8 qts. Thanks...
rjg914 is offline   Reply With Quote
Old 07-29-2008, 08:00 PM   #2 (permalink)
nanoera's Avatar
Date registered: Jul 2008
i know it might be a little bit late...the manual says 8.5 qt and that's what i put in.
'06 R350
nanoera is offline   Reply With Quote
Old 08-01-2008, 10:32 AM   #3 (permalink)
chucelli's Avatar
Date registered: Aug 2006
Vehicle: 1983 300DT, 2000 Z3, 2007 R320 CDI
after extracting the oil out with my extractor, I end up putting in exactly 9 quarts to bring it to the middle of the dipstick. I'm pretty anal about extracting every bit of oil out though..
chucelli is offline   Reply With Quote
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK Class 27 08-05-2008 08:58 PM
torque numbers for oil drain plug & oil filter canister? ProV1x W210 E-Class 2 12-30-2006 01:41 PM
Are these gaskets light or heavy wear? (Oil pan & oil filter) Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 9 08-24-2006 07:57 AM
HOWTO: Replacing Cam Oil Line Fittings (Oil Guides) on the 119 (5.0L) V8 inetd W140 S-Class 3 12-02-2004 10:01 AM
