Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 08-29-2008, 08:58 AM   #21 (permalink)
Vehicle: 2004 E500, 2006 R500, 2003 Lincoln Aviator
Send a message via AIM to Benz-O-Rama
Originally Posted by ptbowman View Post
My 2007 R definitely does not have rockers. Left button is "downshift" only, right button is "upshift" only.
I believe the rockers are on the 2006's only. My 2006 R500 has rockers on both sides of the wheel.
CURRENT
2004 E500 - Brilliant Silver/Charcoal, Appearance pkg, Premium Package, Nav, Xenon, Heated/Vent seats, Dynamic seats, Keyless-Go, Clear corners, 19" MRR GT1's, Lowered via Star Diagnostic and Jangy-fied front links, Sprintbooster, K40 Stealth radar detector w/Laser jammer, V60 Bluetooth, E63 spoiler, power folding mirrors
Benz-O-Rama is offline   Reply With Quote
Old 08-30-2008, 07:46 AM   #22 (permalink)
Date registered: Jan 2007
Thank you -- had no idea! I keep learning about "hidden" features from other owners... not enough time to go go through that huge owner's manual (which could easily be cut down to a 1/4 of its size without losing anything...).
thanks for the tip. it works on 2007 R-350 also.
LLCD is offline   Reply With Quote
Old 09-02-2008, 03:45 PM   #23 (permalink)
Date registered: Jul 2008
Vehicle: 2007 R350 4MATIC
Originally Posted by R. Reyes View Post
You can up/down shift with both the left and the right shift buttons on the back of the steering wheel. comes in very handy after some getting used to it, if you use manual mode a lot.
If you turn off the trac control (as much as you can), in manual you can get the back of the 350 to step out in 1st and 2nd pretty easily. Also helps if it's wet from rain, makes it much easier. But it is hard to control as even with the traction off, it's never really off and you have to fight with it constantly.
But it is possible to get a nice donought.
Is the trac control simply on/off or are there different levels of defeat? I have an 07 R350 and from what I can tell you push the button and the triangle warning appears on the dash...not sure what exactly is defeated or is the amount of "slip" allowed is simply increased.
latapx is offline   Reply With Quote
Old 09-03-2008, 12:48 PM   #24 (permalink)
Date registered: Jun 2005
Vehicle: -90 500SL
When the trac control is shut off, it is still on. You are allowed more "drifting" but if you go to wide, it cuts you off....
2002 CL 500
x -500 SL
x -R 320 CDI
SLNorway is offline   Reply With Quote
7 speed automatic question el-nino W204 C-Class 10 03-04-2008 08:49 AM
4 speed tranny question daryn R/C107 SL/SLC Class 10 10-22-2006 05:39 PM
speed limiter, question sguabro W208 CLK Class 14 08-11-2005 09:25 AM
Question about Idle Speed TappedOut R170 SLK Class 2 10-03-2004 01:06 PM
Question about speed sensor TMV G-Class 1 03-15-2004 01:41 AM
