Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 08-13-2008, 11:10 AM   #11 (permalink)
Date registered: Jun 2005
Vehicle: -90 500SL
Both side buttons shift up and down. Inwards is down, outwards is up
2002 CL 500
x -500 SL
x -R 320 CDI
SLNorway is online now   Reply With Quote
Old 08-13-2008, 11:54 AM   #12 (permalink)
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
That appears to be the case with certain model years. I recall some confusion in the W164 or X164 sections about the shift button controls as some people had rocker buttons and others regular buttons.
asianml is offline   Reply With Quote
Old 08-13-2008, 01:46 PM   #13 (permalink)
Date registered: Feb 2008
Originally Posted by MB-SV View Post
Thanks for the info, I'll have to try that on my ML.
No problem, my dealer did not know it either. The specialist that walked thru the functions before we got the car told us to push the up button untill "D" was displayed in the gear selector.
I do not know if it works on all MB cars. but on 2008 R-Class it works
(RTFM measage Page 208)
2008R320 is offline   Reply With Quote
Old 08-13-2008, 01:53 PM   #14 (permalink)
Date registered: Jul 2007
Vehicle: 2007 MB R320CDI
Originally Posted by 2008R320 View Post
Just a hint, if you push and hold the "up" shift button for ~2-3 sec, it will go straight into D, you do not need to hurdle thru all gears
Thank you -- had no idea! I keep learning about "hidden" features from other owners... not enough time to go go through that huge owner's manual (which could easily be cut down to a 1/4 of its size without losing anything...).
ptbowman is offline   Reply With Quote
Old 08-13-2008, 01:55 PM   #15 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
Thats how the rocker buttons on back of steering wheel work on the ML too.
S.
2008 Mercedes C300 Sport mars red/black
2007 Lexus IS350 Sport granite metallic/gray
2004 Porsche 986S seal gray metallic/black/black
2002 Jeep KJ Sport white/gray
MB-SV is offline   Reply With Quote
Old 08-13-2008, 02:03 PM   #16 (permalink)
My 2007 R definitely does not have rockers. Left button is "downshift" only, right button is "upshift" only.
Old 08-14-2008, 11:44 AM   #17 (permalink)
MB-SV's Avatar
Tried it on my ML350 today, works great.
Old 08-15-2008, 11:43 PM   #18 (permalink)
Date registered: Aug 2007
Vehicle: 2006 R350
Originally Posted by ptbowman View Post
You downshift with left paddle, upshift with right. Center display, between speedo and odo, indicates which gear you are in. Normally it says "D". But say you are going down a steep hill and want to use the engine to help brake, hit the left paddle. If the transmission was, for example, in 5th gear, it will indicate D4 after you hit the paddle once. Keep tapping the left paddle, and it will go to D3 then D2 then D1. If you are in D4 and want to go back into the normal automatic mode, you need to tap the right paddle 3 times: D5, D6, and then it will say D when it's back in automatic. If it indicates anything from D1 - D6 you are in manual mode. Sounds confusing, but it's actually pretty straightforward. The only thing I don't like is it's too easy to brush your fingers across the left paddle when you are steering, putting the vehicle inadvertantly into a lower gear.
You can up/down shift with both the left and the right shift buttons on the back of the steering wheel. comes in very handy after some getting used to it, if you use manual mode a lot.
If you turn off the trac control (as much as you can), in manual you can get the back of the 350 to step out in 1st and 2nd pretty easily. Also helps if it's wet from rain, makes it much easier. But it is hard to control as even with the traction off, it's never really off and you have to fight with it constantly.
But it is possible to get a nice donought.
2nd place...is just the first loser.
R. Reyes is offline   Reply With Quote
Old 08-16-2008, 09:55 PM   #19 (permalink)
Date registered: Jul 2008
Just got back from a trip to Steamboat Springs and the paddle shift really came in handy on the grades.
Jumpback is offline   Reply With Quote
Old 08-26-2008, 12:18 PM   #20 (permalink)
jtreeves's Avatar
Date registered: Oct 2003
Vehicle: 2007 R500
When autocrossing, starting in D2 holds the car in that gear until the engine hits the rev limiter. It'll upshift to the next higher gear. Works the same with older cars as well (C320, SL500).
jtreeves is offline   Reply With Quote
7 speed automatic question el-nino W204 C-Class 10 03-04-2008 08:49 AM
4 speed tranny question daryn R/C107 SL/SLC Class 10 10-22-2006 05:39 PM
speed limiter, question sguabro W208 CLK Class 14 08-11-2005 09:25 AM
Question about Idle Speed TappedOut R170 SLK Class 2 10-03-2004 01:06 PM
Question about speed sensor TMV G-Class 1 03-15-2004 01:41 AM
