I was hoping someone here has done it and have some pics.
I bought mine from ParkPlace/Mercedes/Rclass. Not the same as the OEM which has the same form on the front console. mine is simple one just to hold the can soda and some CD/DVD stuff.
Hi did the center console come with the bracket that bolts to the floor? It seems that this bracket bolts to the floor then the console attaches to this bracket. HTH...
The part number for the bracket is. a251 680 32 14
Yes, it did come with two big bolts and nuts, however, the area where the console supposed to be installed is covered by carpet and I hate to cut up the carpet until I am 100% sure
Do you have a pic of it or the ebay link that you bought it from? I wouldn't cut the carpet either. Your gonna have to do it the hard way and pull the carpet so you can see what your doing before you cut the carpet. I'm sure once you remove the carpet you will see the attachments points for the lower bracket. Once thats bolted in then you culd cut the carpet where needed....
