Hello,
Some months ago I replaced my B200 rear brakes (discs and pads). This week a grinding sound started in the left rear wheel. I removed the wheel and disassembled the brake to find that the outer pad was worn out. The inside pad had some wear but not as the outer one. I replaced the pads and did a test drive, upon my return I found that the left rear disc was pretty hot in the external part while the right rear disc was a little hot only. What could be causing this uneven wear? The sliding pins are not stuck.
Any ideas?
Thx!
Any ideas?
Thx!
