Recently had occasion to replace my Serpentine Poly V-Belt on my B180 CDI.
Discovered that with very restricted space to access and lock on to the Tensioner Pulley 15mm nut to slacken off and replace belt I needed a special long spanner. These are available from a German company but with postage cost is prohibitive to purchase from Australia and one only uses such tool very infrequently. I then accessed a U.K. website run by Bert Rowe (Lofty) primarily concerned with the 'A' Series models, and picked up the idea of making your own tool to carry out this job. I purchased a 600mm length of 15mm diameter steel and a 15mm ring spanner very cheaply, cutting the spanner in half and getting it welded locally to the end of the length of steel. I then slid the steel shaft into a plastic sleeves to make it easier on the hands, but plastic tape would do the same job. I will obviously use this tool again at some future date, however it could be useful for any member contemplating replacing the V-Belt on their "A" or "B" series Mercedes and saving some money doing it themselves and also in making the tool themselves.
