Looking at the engine you should see an aluminum cover (~5"x6") at the top right side of the engine. This is for the B200 and hopefully the Turbo is the same.
Around that cover is a black plastic frame(maybe 2" wider than the above aluminum cover) which pivots at the back near the firewall.
Do not remove the aluminum cover!! Just below the aluminum cover are 2 "Torx 20" screws in the black plastic. Remove those 2 screws and pivot the black plastic back and the filter is exposed. Lift the tab at the top of the filter and change it out with same. Clean and vacuum all dirt and dust out and make sure that the fine black rubber seal is in place before closing the cover.
Note and mark which way it goes back and make sure that the bottom is well located and the top tab is also properly located.
