6.
CLEAN ... everything was carefully cleaned ....
new oil filter ....
7.
assembly ....
change the oil sump gasket,
install new filter on gearbox,
install oil sump back on gearbox,
change copper washer,
turning drainage pin on the converter,
turning drainage pin on the oil sump ....
8.
Filling gearbox with oil ....
Here the filling hole with protected pin ....
Broke lid on the security pin and pushed it down, then slipped the plug from the hole ...
Now open oil and fill in the hole ....
now 6 liters out, 6 liters inside ....
9.
Now start the car, only idling, start to move the gear lever between positions, such as the detention of about 10-20 seconds of each ....
looked underneath for leaks ..... i hope that no such ....
after the move several times in all gears, stop the engine and measure the oil level ...
If all OK, put back the plug in filling hole, put back the security pin ... put back metal shields under the car and you good to go ...
That's all folks .....
sorry for my English ....
may the force be with you !
