Rear Hatch Handle - Stuck! - Page 2 - Mercedes-Benz Forum
post #11 of 23 (permalink) Old 12-14-2009, 06:13 PM
W245 Moderator
Samoila Stefan's Avatar
Vehicle: 2009 C300 4MATIC
Quoted: 5 Post(s)
Speaking of hatches... my struts don't seem to recoil as before... moisture or damage, I'll giv'em a lube next time around... (almost knocked my head one time believing they pulled up the door already LOL)
Mercedes Benz B Klasse 2006
Hergestellt in Deutschland
"In giving advice, seek to help, not please your friend." - Solon (638-559 BC) Greek lawgiver & politician.
Samoila Stefan is offline
post #12 of 23 (permalink) Old 12-14-2009, 06:33 PM Thread Starter
brad_r's Avatar
Date registered: Mar 2008
Vehicle: 2009 B200T
Samoila - that happens to mine when it's cold! I'm smashed my head a couple of times... I pretend I meant to (of course).
brad_r is offline
post #13 of 23 (permalink) Old 12-14-2009, 10:36 PM
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Quoted: 65 Post(s)
Send a message via Yahoo to Mike Tee
Same here, the pressure is too weak. Mine have been changed once already. I remember the good old days of springs, they were more reliable.
2008 Mercedes-Benz B 200 5 speed
2006 smart BRABUS Tailor Made Canada 1 cdi cabriolet
2013 Ford Fiesta SE 5 speed, for the kids
1966 Peugeot 404 Coupé Injection, restoration underway
Mike Tee is offline
post #14 of 23 (permalink) Old 12-16-2009, 02:16 AM
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Quoted: 2 Post(s)
Whatever you do don't put oil on the strut shafts it will knock the seals out in no time.
kdbcom is offline
post #15 of 23 (permalink) Old 12-16-2009, 12:14 PM
Date registered: Sep 2009
Vehicle: 92 400E, 06 B200T
Hmph, my hatch is stuck too. Thought it was the cold weather, but it's +8 C in Vancouver today, so there goes that theory...is there a manual release on the inside the hatch?
oris642 is offline
post #16 of 23 (permalink) Old 12-16-2009, 02:34 PM
kdbcom's Avatar
Quoted: 2 Post(s)
Not to my knowledge though you could investigate by taking out that access panel in the back door(hatch) lining. That will show you the switch area (as far as I remember) but the "guts" of the locking is done around the bottom of the hatch in the centre.
When I had my Scenic someone broke the rear windscreen and bits of glass dropped into the lock mechanism (it is very similar to the Bs) and this jammed & stopped the hatch opening. I wonder if something small has dropped in & jammed yours.
You will probably have to access all of this by dropping the seats down and working from inside the boot area which will be tricky. You may find that you cannot access the locking part without getting the boot open which is a catch 22 situation.
Please let us know if you find the solution to this one
kdbcom is offline
post #17 of 23 (permalink) Old 12-19-2009, 11:13 AM Thread Starter
brad_r's Avatar
Vehicle: 2009 B200T
Just had the handle & lock mechanism replaced under warranty (I think the new part might actually be the entire piece above the license plate, including the white license plate lights). For whatever reason, every time it got to around 0 degrees it jammed up - park underground for a few hours and it worked. Anyway, since the replacement it's worked fine.
brad_r is offline
post #18 of 23 (permalink) Old 12-19-2009, 11:27 AM
Mike Tee's Avatar
Quoted: 65 Post(s)
There is some weird "logic" behind the unlocking protocols if, like me, you have programmed your key to open only the driver's door. If you press unlock twice, the hatch opens, but after driving somewhere and stopping once with engine on (for example letting a passenger off) and then stopping again, the hatch won't open without hitting the unlock thing again. Very strange. The multiplex programmers went to town on complicating this function, assuming exactly what the driver would be wanting and in my experience they got it wrong about 33% of the time.
Mike Tee is offline
post #19 of 23 (permalink) Old 12-19-2009, 11:37 AM
kdbcom's Avatar
Quoted: 2 Post(s)
-3 degrees here at present was -8 (which is pretty cold for southern UK) yesterday but apart from rear hatch sticking due to lots of ice around the bottom edge of the hatch & rubber seals the unlocking mechanism seems fine.
Hopefully the problem is just a one (or 2 ) off and not a badly designed catch or batch problem. Mine is an 07 /08 model with the "rubbery" release button.
BTW the diesel engine has started faultlessly at these temperatures with a flick of the "key" it starts within a couple of seconds. Barely time for the heaters (glow plugs) to cut in.
kdbcom is offline
post #20 of 23 (permalink) Old 12-19-2009, 12:38 PM
W245 Moderator
Quoted: 5 Post(s)
I' thinking silicone based, man. Didn't do it yet...
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
Rear hatch stuck AutoSaurus W164 M-Class 1 10-03-2006 02:23 PM
Replaced Rear Hatch Handle/Actuator & Have New Problem dean1969 W163 M-Class 1 08-07-2006 09:27 PM
I installed my Chrome Handle for the Rear Hatch Today AndyFracica W163 M-Class 3 10-25-2003 10:25 PM
Rear hatch Chrome Handle David W163 M-Class 2 04-17-2002 01:28 AM
Does Anyone Know the Part # for the Chrome Rear Hatch Handle? AJM W163 M-Class 4 03-19-2002 12:16 PM
