My 2008 B200 came with 17 inch/continental summer only tires. I have Snows mounted on 16 inch alloys and am wondering what is the manufacturer recommendation for tire pressure for front and rear for 16 inch tires. My door pillar only has the 17 inch tire pressures indicated.
Welcome to BenzWorld! I'll slide your query down to the W245 section, where you're far more likely to garner a helpful response from some like-minded enthusiasts. You might also consider completing your user profile, many find that information helpful in regard to providing you with the best possible response.
Surprising the discrepecies over the models front is the same unladen but load up and the figures are quite different. The CDI is 100kg heavier than the 200 petrol but most of this must be over the front so why the large difference in the laden rears ?
I have both stickers in my car. Derek's sticker inside the fuel filler door and something similar to emeSAP43's sticker at the base of the B pillar on the driver side door. however, the latter sticker has the 17" listings as well.
I found having both stickers odd, because I have 17's on my car and one of the 2 only listed 16" and when I found the other one, the specs were different between the 2. Which one do I follow when I switch to 16's for winter?
I have both stickers in my car. .... Which one do I follow when I switch to 16's for winter?
Of course you would be perfectly safe following the 16" pressure recommendations.
Playing with a few pounds of pressure "equally" on all 4 is a good way to get a feel for what you like best.
