» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W245 B-Class
Old 09-22-2009, 04:25 AM   #1 (permalink)
Date registered: Aug 2008
Vehicle: B 200 Turbo
engine idle problem
Hi,
I am owner a B200 Turbo (second hand) with CVT of 2 months and I am following problem:
Engine idle is not constant ( up and down between ~ 750 RPM and ~800 RPM).
I went to Mercedes dealer and they rewrote the parameters of computer, but without effect.
I read on a german forum that is normal to do so because of the automatic transmission.
It is possible?
Any suggestion is welcome!
Thank you!
auras1 is offline   Reply With Quote
Old 09-22-2009, 02:34 PM   #2 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Hi auras1 & welcome to the forum, I think this has been posted before on this forum possibly a couple of years ago & also possibly within the past 6 months. You will probably need to trawl through the posts to get an answer unless one of the members that had the problem notices your new thread.
Where are you located by the way ?
kdbcom is offline   Reply With Quote
Old 09-22-2009, 06:47 PM   #3 (permalink)
Date registered: Jan 2007
Vehicle: B200 Turbo
Do you think the idle is fluctuating a lot, or do you just think it's rough?
Even for a 4 cylinder, the B200 Turbo is not a smooth engine at idle - pretty decent when cruising and overtaking (in my opinion).
My idle has been "rough" since new and 33,000 km later is no better or worse. I've decided to find it a charming quirk of the car.
Jeff
jeffplastow is offline   Reply With Quote
Old 09-23-2009, 05:31 AM   #4 (permalink)
Hi Kdbcom,
I am from Romania.
Hi Jeff,
You described very well my observation relating my idle. Yes, it is "rough".
This happens because is a turbo engine?
The same engine but without the turbo ( only B200 model) not has this "rough" idle?
Thank very much!
Auras
Old 09-23-2009, 11:55 AM   #5 (permalink)
Date registered: Apr 2006
Vehicle: B200 Turbo CVT 2009, GL320 CDI 2008, B200 Turbo CVT 2006 Gone
Is your A/C compressor running?
Try it without it.
And yes CVT can give the engine fluctuation you describe but it should
not be rough idle.
B200 Turbo 2009
Mountain Grey, CVT, Premium Package, Entertainment Package, Bi-xenon Headlamps Package,
Media Interface
GL 320 CDI 2008
Sanidine Beige, Cashmere beige leather sets, RSE, Premium Package, BI Xenon Package, Rear Climate Package, Distronic, Running board, Keyless Go
B200 Turbo 2006 gone
B200Turbo is offline   Reply With Quote
Old 09-23-2009, 01:35 PM   #6 (permalink)
Date registered: Aug 2009
Vehicle: 2006 B200T
I have a 2006 B Turbo and it idles a little rough. Not as refined as the larger Benz's. It's quiet and drives smooth, but when it sits there, regardless of gear selection, you can just visibly see the steering wheel tremble and feel it in the car. It's not that bad, but I think it is more than a Benz should have. My 2 cents.
vanctour is offline   Reply With Quote
Old 09-23-2009, 01:47 PM   #7 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
My B200 holds steady.
Old 09-23-2009, 02:12 PM   #8 (permalink)
kdbcom's Avatar
Possibly just a problem with the turbo cars then ?
Members have complained of vibration through the pedals of the diesel cars but I think this is a different issue.
Old 09-23-2009, 02:26 PM   #9 (permalink)
Vehicle: 2006 B200T
My old Ford shook like an earthquake hit! Put it in neutral, and it was like the engine was off. With my B, the shakes are like a new top loading washing machine, regardless of Neutral gear or Drive gear. Nothing to run back to MB about, but I would have thought that MB's would be next to flawless in this department.
Old 09-23-2009, 06:02 PM   #10 (permalink)
Vehicle: B200 Turbo
That is a exactly like my car. The RPM can fluctuate a bit at idle, but overall it is fairly steady. It's the vibrations through the steering wheel I find slightly annoying. I'm assuming it has something to do with stiff engine mounts and it's location.
I have a feeling the turbos are affected more. I've driven a number of non-turbo loaners and they do seem smoother.
1996 SL600 engine idle problem Jimmy G R129 SL Class 17 11-12-2008 05:57 PM
idle problem and engine stall voda W124 E,CE,D,TD Class 5 11-26-2007 11:32 AM
1993 300E Idle-Problem, Engine Harness is replaced! Its kinda weird... RaehZa W124 E,CE,D,TD Class 3 08-29-2006 06:01 AM
Engine idle problem Talon Load W203 C-Class 2 05-16-2006 07:31 AM
Warm V12 engine, strange idle problem at startup pcmaher W140 S-Class 0 03-27-2005 07:59 AM
