» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W245 B-Class
Old 11-07-2008, 12:43 PM   #1 (permalink)
brad_r's Avatar
Date registered: Mar 2008
Vehicle: 2009 B200T
Steel wheels from last car - probably won't fit?
Hey guys... I think the answer is pretty obvious, but I thought I'd throw it out there to those who know a bit more about this stuff:
My old steel wheel from my last car (05 Saab 92x Aero) had a 5x100 bolt pattern and an offset of 50mm.
I'm ASSUMING these won't fit on the B200?
I'd rather know in advance so I can at least try to sell them heading into winter tire season. Luckily, my old tires are 205/55/16... so I should be fine there.
Thanks in advance.
brad_r is offline   Reply With Quote
Old 11-07-2008, 12:51 PM   #2 (permalink)
martman's Avatar
Vehicle: Black B
Thanks in advance.
In the B's manual:
Rims: 6J X 16 H2
Wheel offset: 46 mm (1.8 in)
Your old rims may fit - as far as the bolt pattern is concerned, but your tires may rub. If it does fit, make sure your old rims are also hub centric.
Your old tires are good to go with the B, though.
Cheers,
martman is offline   Reply With Quote
Old 11-07-2008, 01:30 PM   #3 (permalink)
brad_r's Avatar
Vehicle: 2009 B200T
Thanks Martman.
What's the "6J" represent, and the "H2"?
And what did you mean by "Hub centric"?
Old 11-07-2008, 03:11 PM   #4 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
From "Honest John" on the web
Quote "The the 6 defines the width (in inches) and the J defines the shape of the cross section of the wheel rim - the area where the tyre sits. It does not define the PCD of the bolt holes, wheel offset or anything else, so you can't assume another 6J wheel will fit. J is one of the most common sections,but there are others.
Regards
John S
" unquote
This seems to answer the question quite well
H2 appears to mean double hump (see link below)
If you want info on wheel types go here :-
http://www.tyreline.com/wheel_tyre_i...measurment.htm
If you want info on tyre markings go here :-
http://www.tyreline.com/wheel_tyre_i...e_markings.htm
kdbcom is offline   Reply With Quote
Old 11-08-2008, 08:21 AM   #5 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Thanks Keith....great info.... and you somehow seem to have it right at your fingertips.
Derek
Old 11-08-2008, 09:25 PM   #6 (permalink)
guenter's Avatar
Date registered: Nov 2006
Vehicle: '89 E300, '06 B200, '03 Mustang conv., '95 Cavalier (w. beater)
All mercedes are 5x112, so no go.
cheers, guenter
had and gone: Ghia Type1, TR4A, Beetle, Ghia Type3, Westfalia, 240D, Mazda323, 190E.
next: SLK 280 (manual) or VW diesel roadster
guenter is offline   Reply With Quote
Will these wheels fit my car? AlphaWolf W210 E-Class 3 07-22-2008 06:51 PM
Will these wheels fit my car? wildhorse R170 SLK Class 12 07-20-2007 08:16 PM
will these wheels fit my car ??? jimmypop W126 S,SE,SEC,SEL,SD,SDL Class 3 05-14-2007 11:25 AM
Will these wheels fit my car? 560sel W126 S,SE,SEC,SEL,SD,SDL Class 4 05-11-2006 09:45 PM
Will these wheels fit my car? Mr. Corporate W203 C-Class 5 10-19-2005 04:03 PM
