Approximately 0.4 liters per 5000 km on the last oil change.
The pic is deceiving.
I'll have to get it out for a high speed spin....
A little rub with a wire brush and it cleaned up nicely but I was hoping for a nice warm brown when I pulled it.
Looks like lots of carbon build up especially on the ceramic, could cause missfire if it gets worse. Oil looks a lot different so I would not worry. Time to put the pedal to the metal and burn it off ( long hard run ) and then take the plugs out to recheck. If the plugs still have that appearance maybe a different brand or a higher heat range.
I checked my oil tonight at 10,000 km and it's down _perhaps_ 0.4 L. Hard to tell, last time I checked it was in Utah after a high speed run, so the oil was a lot hotter. So maybe 0.04 L/1000 km, about half of Derek's car, still perfectly fine and no topping up needed between 15K changes. I'm stretching this one to 15 K because 6000+ was done in a week on a road trip, so the oil should be fine after 5000 more km.
About the plug, it looks a little shiny on some of the black area, hence my oil comment. But with only 0.4 L gone after 5 K km, that can't be oil, must be a photo reproduction issue.
Picked up 4 plugs from the stealer.
Outside of the box, you can't tell what it is. Inside it's a Bosch # F8DER and only available from Germany.
Auto Electra says it's also only available from Germany and is again replaced with Bosch #SQR8DE
I would have preferred to have purchased a better (long life) plug if I had had that option.
Derek
Looks like a tedious job, not sure if it can be any harder. I'm assuming the car started and ran even better than before,so it was worth it.
Did you ever get a price from the dealer to replace the plugs???? I always try to get a price, it always makes a job more satisfying to see the value of your labour.
In your list you show a Red Box that is available locally, but you fail to mention how many to order
