» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 05-09-2008, 01:18 PM   #1 (permalink)
madsen_b
Date registered: Dec 2007
Post Cleaning/Wiping interior
Does anyone have advice on what to use to wipe the dash and plastic surfaces in the B? A regular cloth with mild soap does nothing. This little cracks harbour dust and dirt and I don't want to use a brush. Not sure if MB recommends a cleaning method.
Thanks!
Edmonton, Canada
madsen_b is offline   Reply With Quote
Old 05-09-2008, 02:54 PM   #2 (permalink)
BeeClass
BeeClass's Avatar
Date registered: Nov 2007
Vehicle: B 200 T
I use a small california mini duster for dusting the interior. It works like a magnet - very well. Takes about one minute for the interior and two minutes for the exterior.
I have its big brother too for the outside- Amazon.com: california mini duster
BeeClass is online now   Reply With Quote
Old 05-09-2008, 03:14 PM   #3 (permalink)
martman
martman's Avatar
Date registered: Mar 2008
Vehicle: Black B
Quick guide to cleaning the interior of your car.
Your car's interior is as important as your exterior. Here are some info to help you keep your
interior in tip top shape.
1. Have a look at your interior and survey what needs to be done. Here's a quick checklist
a. windows
b. floor mats (carpets)
c. drink trays (coffee stains, pop stains, etc)
d. fabric/leather (does it need to be cleaned?)
e. dash (is it very dusty?)
f. air vents
g. interior side panels (any scuff marks?)
h. trunk
Take a can of air and blow into the nooks and crannies to get rid of the dust and gunk stuck in tight
spaces. This will prevent the dust from spreading around when you use your fan later on. Spray the vents as well as it will help purge a lot of the dust out. Next step is to vacuum the car. Make sure to get in between the seats as well as other crevices. If you can't suck up some of the particles, use a lint roller or use a brush to get the particles to the surface. Be sure to wipe down the surfaces to get rid of the dust. Also use an interior panel cleaner to get rid of marks and dust on the door panels.
For those of you who have leather, you should be applying a leather protectant/conditioner every few months (usually 3 to 4). If not, the leather will lose it's moisture and you will find that it looks dull, feels hard and later on will start to crack. Some product recommendations are: Lexol leather cleaner/conditioner, Meguiar's Leather Cleaner/conditioner. I found these to be worthwhile to use as it does not leave a super shiny surface and when it dries, makes the leather look 'new' without that artificial shine to it. You should allow the conditioner to cure overnight before sitting on it else it won't get absorbed into the leather. Also note that your seating surface may be a little slippery the first day but that usually goes away quite quickly.
As for the fabric, just keep it clean by vacuuming and also apply some scotch guard. The scotch guard will prevent water, juices, food from being absorbed too deeply into the carpet or fabric which means it is easier to clean if there is ever a mess. Another product you may want to consider is 303 Fabric protection. You have to let the stuff dry and cure but it does make the surfaces repellent to stains for quite some time.
For windows, you will need a good quality window cleaner. You can purchase them basically anywhere. Some brands that come to mind are: Stoners, Rain-X, Auto-magic. Stoners is works quite well. Any glass cleaner will leave streaks if you don't wipe them off properly. You need a good microfiber towel to absorb the product and at the same time, remove the product from the windshield. Any streaking that you see is what you have not removed. The best combo that I've found, windex and newspaper. Gets it super clean!
When you clean your windows, make sure the windows are cool, and that you have 2 cloths to do the work. You will need one dry and one wet one (don't wet it with water, it will become damp from wiping off the cleaner). Once you spread the product on the windows, use the dry towel and clean off any residue before it dries. If you leave it to dry, it will leave streaks and spots. If your window is hot or warm, it will leave some nice rainbow streaks for you to freak out at. Trust me, it took me awhile to learn. Make damn sure your windows are cool and not warm or hot.
One other spot that is of interest would be the door jambs. Now, I consider it the interior of the car and others would consider the exterior. Make sure you give it a good wipe down as after a rain storm, snow fall or whatever, it tends to get really dirty. This goes for the engine bay as well. Just wipe around the edges to get rid of the junk. The product that I recommend to clean the door jambs and the edges of the hood is Meguiar’s quick detailer. It loosens the dirt and all you have to do is wipe it off. Easiest cleaning product I've used aside from car soap.
You should try to vaccum your car at least once a week. This keeps the debris from settling into the carpet which makes it difficult to vaccum out in the future. If you find debris that are hard to vaccum, you can use a toothbrush to loosen it up or you can buy an interior brush for that purpose.
Martman
Black B200
http://rides.webshots.com/album/5630...Pa?vhost=rides
martman is offline   Reply With Quote
Old 05-09-2008, 06:40 PM   #4 (permalink)
Bill F
Bill F's Avatar
Date registered: Oct 2007
Vehicle: B 200 Turbo 2007 SAAB 9000
Martman
If that is the quick guide please don't look inside mine. I have found the easiest way to clean the inside is
a) roll down windows
b) open sunroof
c) drive as fast as you can until all dust is blown out.
Sometimes, depending on what you are following you or the road conditions, you can acquire fresh dust to enjoy.
Usually on rainy days I use a small household duster (swifter???) to grab all the dust and like BeeClass it only takes a few minutes.
I never eat or drink in any car and that alone is a major factor in keeping clean.
Bill
Bill F is offline   Reply With Quote
Old 05-09-2008, 07:00 PM   #5 (permalink)
Mike Tee
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Send a message via Yahoo to Mike Tee
My interiors have never been cleaned like that and they look OK, even in my 20 year old car! Life is too short to get the Q-Tips out
2008 Mercedes-Benz B 200
2005 smart fortwo cdi pulse cabriolet, loaded
1966 Peugeot 404 Coupé Injection
1989 Peugeot 405 DL, 366,000 km
Mike Tee is online now   Reply With Quote
Old 05-09-2008, 07:05 PM   #6 (permalink)
Bill F
Bill F's Avatar
Q-tips do make great cleaning tools for cleaning an ink jet printer but seem to heavy to carry out to a car.
Bill
Old 05-09-2008, 09:10 PM   #7 (permalink)
martman
martman's Avatar
Vehicle: Black B
I use Q-Tips for my ears!!!
Old 05-09-2008, 11:20 PM   #8 (permalink)
Mike Tee
Mike Tee's Avatar
Not in the ear canal, I hope
Some car detailers use them to clean parts of the interior, believe it or not. I believe that degree of attention to cleanliness is not healthy, LOL
Old 05-10-2008, 07:23 AM   #9 (permalink)
Bill F
Bill F's Avatar
Not a good practice to put any thing in your ear other than your elbow
Bill
Old 05-11-2008, 06:41 AM   #10 (permalink)
jeffplastow
Date registered: Jan 2007
Vehicle: B200 Turbo
I use the dry swiffers for dusting the interior parts (dash, door panels, etc). I find they pick up the dust very well. I can't stand the shiny armor all type stuff, and find that dash dressings tend to encourage MORE dust. I'd like to find a matte product that actually protects (I've heard that armor all-like products often do more harm than good).
I just use water with a little soap to clean things like door sill area, and around the cup holders.
Seems to work, but then I don't tend to make too much mess in the car, so I don't have any serious stuff to clean up.
Black carpets are a PITA to keep clean though. I'll go back to grey on the next car!
Jeff
jeffplastow is offline   Reply With Quote
wiping front wiping when starting engine stev W164 M-Class 6 12-05-2006 12:04 PM
Cleaning interior Pak Detailing and Car Care 4 08-04-2006 02:41 PM
Cleaning the interior CP1 R171 SLK Class 2 01-16-2005 06:33 PM
Cleaning the interior hongkong_r1 R171 SLK Class 3 10-03-2004 03:21 PM
