» Site Navigation
» Other Sites
Old 04-26-2008, 09:54 PM   #11 (permalink)
jtcb
jtcb's Avatar
Date registered: Apr 2007
Can you post some pics? Does it looks like a factory install and not just a head sticking out of nowhere? Any drilling requires? Do you need to keep the glove box open?
jtcb is offline   Reply With Quote
Old 04-27-2008, 08:30 PM   #12 (permalink)
ecmiyake
Date registered: Mar 2008
Vehicle: 07 B200 comet Grey
that's a picture of what it look like in the glove box. (the upper left hole above the vent hole) just like where the factory one's located? and yes, there's drilling in order to install the end of the aux input properly.
ecmiyake is offline   Reply With Quote
Old 04-28-2008, 10:07 AM   #13 (permalink)
B200Turbo
Date registered: Apr 2006
Vehicle: B 200Turbo CVT 2006, GL 320 CDI
yes you have to drill one hole in the glove box
otherwise it is remove upper vents above radio disconnect 4 way flasher,
pull out the bottom panel where heating controls remove 4 screws that holds the radio pull out radio without disconecting it, plug in the wire. Pull the wire behind to glove box.
Remove six screws around glove box remove glove box drill hole plug it in the end reinstall back check if it is working. reinstall back slide back the radio careful around the wires when sliding it back. Screw back 4 screws to hold the radio. install bottom panel.
plug in wire for 4 way flasher slide in upper vent.
I do recommend to buy tools form mercedes very easy to do with merc original tools
Done by myself careful first time no problem.
B200 Turbo
Comet Grey, CVT, Premium Package, 17" wheels10 spoke
Harman Kardon sound system, 10 Way power front seats manually adjustable steering 4 way.
GL 320 CDI
Sanidine Beige, Cashmere beige leather sets, RSE, Premium Package, BI Xenon Package, Rear Climate Package, Distronic, Running board, Keyless Go
B200Turbo is offline   Reply With Quote
Old 04-28-2008, 12:02 PM   #14 (permalink)
kdbcom
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Great instructions B200Turbo, could you please give some idea of the cost of the M/B tools to do the job. Thanks
kdbcom is online now   Reply With Quote
Old 04-29-2008, 12:08 PM   #15 (permalink)
trout
trout's Avatar
Date registered: Jul 2006
Vehicle: B Class 200SE
This site gives details albeit in German Elchfans.de - für alle Fans der Mercedes Benz A-Klasse
Plus Quote from previous thread below,also try the search facilty there is a lot about this in general and some B class details
Originally Posted by jeffplastow View Post
To answer a prior question - I've installed the aux in cable (didn't care to spend the outrageous price for iPOD install) and it works very well. It is standard on the '08s now and I took issue with it not being standard from the beginning given the price point of the car. Here is a copy of what I've posted before on the installation - there are numerous better postings with pictures, etc. out there, but for what it's worth...
It is quite simple to do. You need three parts:
169-540-49-08 (cable harness - $36.80)
140-589-02-33-00 (tool for airvents - $24.16)
115-589-03-59-100 (wedge for panel below radio - $14.16)
Be careful when removing the panel below the radio. Numerous pictures have been posted showing the removal of this piece and they are MISLEADING!!!!
Removing this panel is without a doubt the hardest part of the job and NEVER consider doing this in cold weather or I guarantee it will snap.
The problem is that every picture I've seen shows the wedge being used on the bottom edge of the panel (by seat heater controls). This is no good! The clips are actually on the side of the panel. Another problem is that this panel is actually two pieces! There is the top layer that is "permanently cliped/fused" to the lower main panel that is held by the clips on the side (hence the wedge to release them). When I first used the wedge, I began to leaver off the top panel and broke a number of the "permanent clips" - luckily I was able to repair.
For those interested in the wood kit, I believe it is this top layer only that is replaced during the process and the underlying panel is the same.
There you go - my bit of wisdom for the day - make sure you are removing the main piece that has both layers and not just the top one!
Jeff
trout is offline   Reply With Quote
Old 05-19-2008, 01:00 PM   #16 (permalink)
jtcb
jtcb's Avatar
ecmiyake, do you remember who is your contact for the install? Is it Brian or Victor or others? I called and asked them about the install on a B-class but none recalled about installing to that car..
Old 05-19-2008, 09:38 PM   #17 (permalink)
ecmiyake
you're talking about audio line at burnaby right? i believe i've talked to brian. my car was done on a saturday. only took them like 20 mins for the whole job.
Old 05-19-2008, 10:08 PM   #18 (permalink)
jtcb
jtcb's Avatar
Yes Audioline. Oh ok.. Brain wasn't around the day I called. I'll try again. Thanks.
Do you happen to have the part# for the Aux cable handy? I found one similiar cable on Ebay and I wonder if they are the same.
Old 05-20-2008, 08:04 PM   #19 (permalink)
jtcb
jtcb's Avatar
Another question. Is this needed in order to plug the mp3 player to aux cable in order to play in car stereo? Is this what you guys use?
For only $1.42 each when QTY 50+ purchased - 3.5mm Stereo Plug/Plug M/M Retractable Cable (Black) | 3.5mm Audio Cables
Old 05-21-2008, 01:12 AM   #20 (permalink)
kdbcom
kdbcom's Avatar
Either that or a non retractable would do fine.
W203 Ipod Aux Cable brem01 For Sale, Trade & Wanted Items 5 03-21-2007 09:32 AM
C32 Aux Connecting Cable jmorris644 W203 C32 AMG, C55 AMG 2 02-27-2007 08:21 PM
Cable for Aux input in a G500 The_Analyst Audio & Telematics Forum 0 11-06-2006 09:11 AM
Cable to connect IPOD to AUX FM247 R171 SLK Class 10 04-06-2006 04:31 AM
Special Aux Cable Needed? whisperbenz W220 S-Class 5 03-02-2006 03:21 AM
