» Site Navigation
» Other Sites
Old 04-09-2008, 06:39 PM   #1 (permalink)
A.N.
A.N.'s Avatar
Date registered: Apr 2007
Vehicle: 06 White B200T
Changing the licence plate lights
Anyone know how to change them? It doesn't say in the manual and I'm not sure if I should pry open that panel on the hatch door or unscrew the black handle trim. Any thoughts?
Anthony
A.N. is offline   Reply With Quote
Old 04-10-2008, 02:52 AM   #2 (permalink)
kdbcom
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Mine were just screwed to the panel on the rear hatch door with self tapping screws. I took mine off to mount the number plate on a chrome surround. But there again in Canada they seem to do things differently.
kdbcom is offline   Reply With Quote
Old 04-10-2008, 06:45 AM   #3 (permalink)
A.N.
A.N.'s Avatar
Do you mean the screws on the outside of the hatch on the trim just underneath the chrome piece or the panel on the inside?
Old 04-10-2008, 07:53 AM   #4 (permalink)
Derek Lecours
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Anthony!!
Don't try to pry off the small inner panel.
It's not designed to come off without removing the whole inner panel first.
BTW...Quite a big job.
Old 04-10-2008, 08:25 AM   #5 (permalink)
Derek Lecours
Anthony, I just had a look.
Open the tailgate and stand at the back of the B looking in at the license plate lights.
That black piece of plastic, that holds the 2 lights, is held in place with 4 small recessed torx screws.
Remove them and you should have access to the 2 little lights. Let us know!
Old 04-10-2008, 08:25 AM   #6 (permalink)
kdbcom
kdbcom's Avatar
Unless your version (Canadian) is different from ours that small panel does come off fairly easily for access to the wiper motor. Have taken mine off several times as the washer pipe used to keep falling off. Don't think removing it would help much unless your numberplate is actually nut & bolted through the rear hatch door. Seem to remember there was not a lot of room down the back of the inner panel to work in.
Our number plate screws are just self tappers (4 in my case but some dealers use only 2) through the number plate and into the recess in the outside of the rear hatch door.
Some dealers use fairly thick double sided tape to hold the numbers plates on but sometimes they drop off.
DOH apologies here I have completely misread the thread heading and have been rambling on about removing number plates & not number plate bulbs.
"I must engage brain before getting into typing gear"
It is a good job Derek is awake
Old 04-10-2008, 08:27 AM   #7 (permalink)
A.N.
A.N.'s Avatar
Thanks for the heads up Derek!! I didn't think that was the way to get at them, I might try the black trim on the outside of the hatch.
Anthony
Old 04-10-2008, 08:48 AM   #8 (permalink)
Derek Lecours
Keith, I know you've removed that little panel with some success but my dealer warned me "not to" and said that the little panel could remain loose if pried.
I'm sure one day I'll have to find out for myself and open everything up.
Old 04-10-2008, 08:55 AM   #9 (permalink)
kdbcom
kdbcom's Avatar
Yes, like a lot of things, once you undo them they never seem to fix back as well. Mine did drop off a couple of times after, but saying that I did have a small plastic strap through one of the clips (to hold the washer pipe) so I dont think it was able to go rright back into its proper position.
As you say best leave well alone if possible, but, if it saves getting a bootfull of water then it's then worth removing as that pipe joint is not that brilliant.
Old 04-10-2008, 11:09 PM   #10 (permalink)
deheld
deheld's Avatar
Date registered: Jun 2007
Vehicle: W245 B-Class 180 CDI
I also did remove the small black panel on the inside. I added some padding to silence the noise from the wiper motor. Panel pulls put easily.
deheld is offline   Reply With Quote
White LED Licence plate lights CLK_GTR W208 CLK Class 5 03-31-2008 05:43 AM
Licence plate bulb question MR888 W210 E50 AMG, E55 AMG 2 09-26-2007 03:43 PM
Changing license plate lights on E300 jlonda General Mercedes-Benz 0 09-26-2005 06:50 AM
the SCARIEST licence plate.... ever amgbnz Off-Topic 8 05-25-2004 07:43 AM
coolest licence plate amgbnz Off-Topic 15 11-23-2003 11:33 AM
