Old 03-24-2008, 06:32 PM   #11 (permalink)
CA-B200's Avatar
Thanks guys. All the poking, prodding, tugging but nothing seems to work and everything seems to look fine but obviously something is amiss It’s always been a little difficult to latch down so maybe something has been out of alignment all along. I guess the MB technicians get another day with my car soon. (MB tech with my car...)
CA-B200 is offline   Reply With Quote
Old 03-24-2008, 09:10 PM   #12 (permalink)
CC Ryder's Avatar
Date registered: Nov 2007
Vehicle: C 230 2008 7 Speed, Silver
If it is just an adjustment of the hood latch, it should not take more than about 15 - 20 minutes to complete. If your dealer offers a pit-stop type service you will be on your way after drinking your complimentary coffee.
CC Ryder is online now   Reply With Quote
Old 03-25-2008, 08:18 AM   #13 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
If you press the hood down softly, can you press the hood down so that the seams of the hood and fenders and headlights lined up properly?
If not, then maybe it's just a hood adjustment. The large black plastic screws on each side are part of the hood adjustment.
With the hood in the raised position, you should be able to spring the mechanism into the locked position manually with a screwdriver. Pulling the hood release lever should then re-release it back to normal.
It will be a quick fix so I hope you're able to post their findings.
Old 03-25-2008, 05:24 PM   #14 (permalink)
CA-B200's Avatar
Woohoo it locked! I kept pulling and pushing on levers, cables, springs anything that moved in the latch or associated with the latch. Then I tried once again to close it and voila...it closed. I’ll have the dealer check the adjustment next service. (I wonder how much that hood weighs...seemed to get heavier by the day...)
Old 03-26-2008, 09:45 AM   #15 (permalink)
Good job!!
We'll have you fixing our B's in no time.
Derek
Old 03-26-2008, 01:27 PM   #16 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Derek
In that case Ca-B200 will have a job for life
kdbcom is offline   Reply With Quote
Old 03-26-2008, 01:40 PM   #17 (permalink)
CA-B200's Avatar
I worked on my first two cars regularly so I couldn't let a latch beat me.
Old 03-26-2008, 04:02 PM   #18 (permalink)
CA-B200, I like your attitude.
I know this forum drags us into complaining too often about our B's.
Most of us really like the way it does things well.
Together we'll hopefully solve the problems that we do get.
It's such a good feeling when we're able to fix it ourselves.
Old 03-26-2008, 04:33 PM   #19 (permalink)
kdbcom's Avatar
Hear Hear, I'll drink to that
bonnet(hood) woodwork1 W203 C-Class 1 10-24-2007 11:51 AM
bonnet(hood) woodwork1 W203 C-Class 0 10-24-2007 11:47 AM
Bonnet/hood insulation RedLiner R129 SL Class 8 10-21-2006 07:50 AM
Bonnet / Hood opening roadsta R171 SLK Class 8 05-15-2005 02:43 PM
SEC Hood (Bonnet) on a SE/L Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 04-25-2002 11:32 AM
