» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 01-17-2008, 01:09 AM   #21 (permalink)
kdbcom
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Antony that is an Aux in socket fitted to mid 07 cars on (UK anyway) it is for MP3s, Ipods, etc it does not give any track names on the display though, just an audio signal into the radio/CD unit.
jtcb it is designed so you can keep anthing in the glovebox cool (from the aircon) ie drinks, sandwiches etc. The French MPVs seem to implement this feature better some keep the drinks almost ice cool.
Thanks Derek, it's a bit chilly to go ripping bit's out now (you know what softies we are over here) will take a look at this in the warmer weather.
kdbcom is offline   Reply With Quote
Old 01-17-2008, 06:38 AM   #22 (permalink)
jtcb
jtcb's Avatar
Date registered: Apr 2007
I don't think that vent hole in the glove box cool stuff that good if it is what it is for. I think the Dodge Caliber has a better cooling glove box and is made specially for drinks.. but I think it is a waste of space and use of the glove box.
jtcb is offline   Reply With Quote
Old 01-17-2008, 08:23 AM   #23 (permalink)
kdbcom
kdbcom's Avatar
I agree with you but if one maker puts them in the others have to follow suit and yes the storage spaces on the B class are abysmal compared to other manufacturers.
Old 02-02-2008, 10:16 PM   #24 (permalink)
jtcb
jtcb's Avatar
Off topic here but related to the hole. I notice there is another hole inside the glove box. I am not talking about the vent hole knob. It is located on the sidewall of the vent knob. It has a sticky foam feel to it. I can't see it, but I can feel there is a hole in there.
I was trying to put some emergency food in the glove box. It feels warm after I went shopping. I am sure I turn the vent to the close position after reading about this vent hole in this thread. I thought somewhere inside must be leaking warm air so I feel my hand around. That's how I discover this hole.
Any idea what it is for?
Old 02-03-2008, 05:06 AM   #25 (permalink)
jeffplastow
Date registered: Jan 2007
Vehicle: B200 Turbo
JTCB,
That is where the aux-in connector goes (or IPOD connector). The sticky part is the foam that covers the entire back-side of the glove box. I assume it is for heat and noise reduction.
jeffplastow is offline   Reply With Quote
Old 02-03-2008, 08:40 AM   #26 (permalink)
jtcb
jtcb's Avatar
So that hole is there for a purpose? They should have cover it with something for those didn't opt for the ipod even though you can't actually see the hole. Another cost cutting I guess? Thanks Jeff for the info.
Old 05-11-2008, 07:16 AM   #27 (permalink)
kdbcom
kdbcom's Avatar
Originally Posted by Derek Lecours View Post
Keith, I've had my glove box out and it's not a big job.
If you get the text sheet up on it, it will explain the steps involved.
Those 4 round caps in the front, cover the 4 screws with a couple more screws underneath.
A little tricky, is making sure the ventilation tube is reconnected as you push it back to the screw holes.
My little vent hole on the left is black also, without anything white, as showing in that pic.
Spot on info again, Derek, followed your instructions and it came out easily.
For any one interested the CD holder is held in by plastic clips in square holes and to remove the holder all you have to do is push the 'lips' on the front 2 clips and the back ones 'Hinge' out of their location holes. A nice easy job when you have the information. Thanks Derek
Whilst I had it out I also drilled a hole in the side of the glovebox for the Aux in cable to come through instead of it going round the side of the glovebox door. It just needs a rubber grommet to finish the job off.
Pictures show the removed Cd Case & one of the clips you have to push back
Removal does give a bit more space in that miniscule glovebox. The Cds will now go in a 20 Cd leatherette case under the seat.
Easy Vario Seat System info required urgently kdbcom W245 B-Class 1 06-20-2006 10:11 AM
Cassette holder removal ??? undrctl R129 SL Class 1 09-11-2005 10:23 PM
Speaker measurements for the 209? Info required urgently... Ashar W209 New CLK Class 2 10-01-2004 06:31 PM
HELP! INFO REQUIRED PLEASE hirevanman Audio & Telematics Forum 5 02-13-2003 11:16 AM
A class info on heated seats required nikconnor W168 A-Class 2 12-29-2002 02:46 AM
