Old 11-18-2007, 06:40 AM   #1 (permalink)
Date registered: Jan 2007
Vehicle: B200 Turbo
Steering wheel trim issue
Hi All,
Just noticed that the "aluminum" trim on my steering wheel is peeling on one corner. I guess this "aluminum" is some sort of foil effect? It is actually quite sharp where it is coming free.
Has anyone else had this issue? I'm not all that concerned at the moment. I'll likely have them fix it at the first official servicing which should be some point between Christmas and Spring...
To me, it looks like they'd have to replace the entire wheel in order to remedy the issue - unless individual components can be ordered. I'm rather hoping the individual pieces are available, because I've often wondered what would happen if one of the function buttons were to go bad and whether the steering wheel is a "servicable" item or just a throw away? For that reason, I try not to use the buttons much (including the volume) out of fear of them breaking!
Jeff
jeffplastow is offline   Reply With Quote
Old 11-19-2007, 06:59 AM   #2 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
I had my whole steering wheel changed when a wire came off somewhere inside and the horn acted up.
No wheels in stock so they took one off a new B!!
I was getting relays picking up and wrong messages in the info screen, not a fun experience!!
Old 11-19-2007, 10:23 AM   #3 (permalink)
deheld's Avatar
Date registered: Jun 2007
Vehicle: W245 B-Class 180 CDI
I have no aluminium trim on my steering wheel.
deheld is offline   Reply With Quote
Old 11-19-2007, 12:18 PM   #4 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Aluminuim trim * on steering wheel is part of the sports pack & standard equipment on the B200 Turbo (UK Versions)
I think the cars for the Canadian market have different option packs & levels of equipment to the European cars
* The spokes on the steering wheel at the 4 oclock & 8 oclock positions have an aluminuim trim on them, apart from that the steering wheel appears to be the same regarding size & buttons etc but the rim is contoured slightly differently & has partially perforated leather
kdbcom is offline   Reply With Quote
Wood trim steering wheel JoeRose70 W210 E-Class 14 07-09-2006 09:29 PM
Wood steering wheel trim JoeRose70 Test 0 06-27-2006 04:07 PM
wood trim steering wheel lockmanmd W209 New CLK Class 0 05-08-2006 05:22 PM
Trim Package steering wheel GreenSLKGuy R171 SLK Class 14 10-22-2004 08:09 PM
Fixing sluggish steering issue / replace steering damper (pics) Rainmaker W140 S-Class 8 09-17-2004 10:51 AM
