Old 10-20-2007, 07:22 AM   #11 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
I would suspect that either the pad cylinders may be sticking or siezed on the defective side or the pads are not moving freely.
Don't do the process below without the assistance of a reliable mechanic.I am just outlining a procedure that may or may not work in your case.
You would need to remove the wheel cylinder assembly and really clean out the part where the pads slide (side to side) making sure that they can slide easily. You can get a special Brake grease these days to thinly smear on the sliding surface.
To check the wheel cylinder movement is a bit tricky, requires 2 people & involves operating the brakes without the pads in ( but with a block of wood or metal to stop the cylinders from coming out of their bores). And a G cramp to squeeze them back in again. This needs to be done several times taking the cylinder nearly to the full travel of its bore .
I've managed to get a several 'sticky' cylinders working properly again this way but it is not for the faint hearted and you need to be a reasonably competent mechanic to undertake this job. The assembly needs to be relatively new (as yours must be) as wear ridges can develop inside the bore and damage the seals if taken to the full travel of the cylinder.
You would be need to bleed the brakes again afterwoods.
The above is just a rough guide to the principle of what needs to be done. A better bet would be to have the whole wheel cylinder assembly replaced but knowing the price of M/B parts this would be expensive.
NOTE
Bear in mind the safety aspect of working on brakes if in any doubt DON'T touch them.
kdbcom is offline   Reply With Quote
Old 10-20-2007, 07:27 AM   #12 (permalink)
kdbcom's Avatar
Thanks JTCB
Am working on this at the moment.
Old 10-20-2007, 08:00 AM   #13 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Originally Posted by kdbcom View Post
I have been hunting ebay for one but no one seems to reply to my emails asking if it covers the B class.
I gave up trying to find a B manual. But I did order the latest ebay manual from Tim Oleary in the UK.(tim_o_leary@hotmail.co.uk) He listed his as the latest, showing all Classes, but no B in his listing. But there it was when I opened it up(for a short time anyway).
All B class models were in the 3 DVD's I received.
But in turning the computer into a server, I couldn't get on the internet anymore!!
So I'm back to square one, chatting with you all. Any suggestions would be great.
I'm thinking of installing it on a laptop that I can plug into our printer for copies when I want. But now I have to buy a laptop, just for the manual!
Old 10-20-2007, 09:58 AM   #14 (permalink)
jtcb's Avatar
Date registered: Apr 2007
Here you go Kieth.
MERCEDES BENZ Set 4 DVD EPC Parts Catalogue & WIS ASRA - eBay Mercedes-Benz, Car Manuals Literature, Cars, Parts Vehicles (end time 23-Oct-07 15:44:44 BST)
jtcb is offline   Reply With Quote
Old 10-20-2007, 10:00 AM   #15 (permalink)
kdbcom's Avatar
Derek Coincidence he (tim) was one I emailed earlier
Thanks JTCB (mind you your contact knows how to charge a real M/B man)
Another avenue has turned up today & I am trying to make some arrangements at the moment. It's like buses all the information turns up at once.
But thanks again guys
PS
Note my new grill (£20 on ebay) in the Avatar. Getting the B set up to my liking now, mind you I got some well scratched arms fitting it.
Old 10-20-2007, 10:05 AM   #16 (permalink)
jtcb's Avatar
It lists right on the auction that B is covered under MERCEDES BENZ MODELS COVERED: EPC.
B - Class
B150, B170, B200, B200 Turbo
Old 10-20-2007, 10:24 AM   #17 (permalink)
kdbcom's Avatar
I missed him before he does not show up on a generic B class search & when I looked up B class manuals I got about 1200 entries. Still I hope I am sorted now thanks.
Old 10-20-2007, 01:18 PM   #18 (permalink)
gsp1's Avatar
Date registered: Aug 2006
Vehicle: B150+Sports
Derek about the "server" problem.... in my pc works just fine.. I just followed the instructions in the info file included and worked ok. I have to admit that its a "heavy" application but it works without problems for me. PM me if you stuck to a specific step so maybe i can help you parallel to mine...
Cheers
gsp1 is offline   Reply With Quote
Old 10-20-2007, 01:25 PM   #19 (permalink)
gsp1's Avatar
NOTE
Keith THANKS.. this is a very useful guide. But i am afraid to touch my brakes myself!... Probably i will wait for some kilometers more to see what happens to the new disc...and if i have the same i will have some words with my dealer again.. (and again...and again )..
Maybe i should have bought a Huyndai
Old 10-20-2007, 02:53 PM   #20 (permalink)
kdbcom's Avatar
Don't say that George we would miss you from the forum.
drum brake to disc brake retrofit 1960 190D ed755 Vintage Mercedes-Benz 5 06-06-2007 09:56 AM
Rear Brake Disc Problem Andy747 R171 SLK Class 4 03-28-2006 05:27 AM
How to remove the rear brake disc on 560sel sladerunner W126 S,SE,SEC,SEL,SD,SDL Class 9 02-12-2006 02:01 PM
Rear brake disc Q karugs W123 E,CE,D,CD,TD,TE Class 2 09-30-2005 09:05 PM
Problem Fitting Rear Brake Disc Rotors over Parking Brake Shoes? Guest (MBNZ) W124 E,CE,D,TD Class 7 04-03-2002 09:22 AM
