» Site Navigation
» Other Sites
Old 03-12-2008, 12:28 PM   #41 (permalink)
jmcc's Avatar
Date registered: Dec 2007
Vehicle: 2008 B200, 2008 Audi A3
Originally Posted by Mike Tee View Post
You can fill your diesel to the brim without any problem.
The 6 L "reserve" is part of the 54 L. I have been getting pretty good numbers on the range, up to 900 when driving with a full tank on the highway.
Sorry to resurrect an older part of this post, but I was pondering this today and did a search - Mike, are you sure the 6L reserve is part of the 54L? I filled up today when the warning came on and put in 53L. I checked my last receipt and find it was 53.8L - very close to 54. These numbers make me think that the total capacity is 60L - 54 L + 6 reserve. Am I wrong?
jmcc is offline   Reply With Quote
Old 03-12-2008, 12:38 PM   #42 (permalink)
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Send a message via Yahoo to Mike Tee
Officially the total is 54 L, of which 48 is non-reserve. You can get more in, especially if the car is on a slope when filling (sloping away from the pump and down to the front. You don't want to overfill the gas tank though as it would totally ruin the anti-evaporative fuel vapour canister.
2008 Mercedes-Benz B 200
2005 smart fortwo cdi pulse cabriolet, loaded
1966 Peugeot 404 Coupé Injection
1989 Peugeot 405 DL, 366,000 km
Mike Tee is offline   Reply With Quote
Old 03-12-2008, 12:47 PM   #43 (permalink)
Mike Tee's Avatar
Originally Posted by Derek Lecours View Post
Mike!! Who really is the true #1!!
The guy in Germany with the B 200 is, I am #2 and you are not in the competition because the on board computer is inaccurate! Relying on it is self-delusion. I found this same margin of error (about 5-7% optimistic) in the C 230 K we drove across Canada in duiring 2004. And that one did not get zeroed on the way, though it spontaneously zeroed itself at about 10,000 km (which I assumed they all did, but that was in hindsight probably a glitch, of which that car had a few).
When I'm at 7.50 at spritmonitor, my After Reset Screen would have shown 7.0 or 7.1. This is based upon the error noted during 12,000 km of actual field results.
The ski trip average wasn't 8.5, it was that in one direction, and in the low 7s on the way home. The 5.5 hours of idling tank, I've not included in the overall figure, but I will add it soon.
At refill time for the past 10 or so fills, the After Reset screen has usually shown under 7.0 L/100 km, sometimes between 6.4 and 6.9. I only started recording this at 5000 km; I can take photos of the screen at refill time, if you like.
It's more meaningful to zero it every time, so you know what your average speed over the fill was, as well as being able to verify the inaccuracy of the OBC.
Derek, until all of your fuel receipts are entered into a spreadsheet, you are not in the game. Come on buddy, get with the program!
Old 03-12-2008, 01:53 PM   #44 (permalink)
jmcc's Avatar
Thanks, Mike, but how do you explain my getting 53-54 L in the tank when the light has just come on? You use the word "officially" - do you think the tank is actually bigger? Gas stations are pretty level! Do you get that much in on your fills according to receipts?
Derek - Mike's thrown down the gauntlet -time to start saving those receipts!
Old 03-12-2008, 02:36 PM   #45 (permalink)
nest18's Avatar
Date registered: Oct 2007
Vehicle: B200 - 2007
mmm, I've always asked myself this question ... HOW accurate are their tanks when pumping ... ??
The most that I've put in mine is 52L, and I remember my girlfriend freaking out cause the light was on and a message appear in the cluster ... I guest you can't do that good old "out of gas, stuck alone with me darling" trick with my B ...
Daniel
Spritmonitor.de
nest18 is offline   Reply With Quote
Old 03-12-2008, 03:03 PM   #46 (permalink)
Mike Tee's Avatar
I guess the tank is about 55 L but the filler neck is long and if the fuel fills it to any extent, that could add a few L. But as I said, it's dangerous because the charcoal canister could be damaged. Maybe the fuel cutoff on the pump nozzle you were using was not calibrated sensitively enough.
I checked the On Board Computer results that I have recorded on my car, and the mean value over the past ~7000 km (since I've been recording the OBC value at fill time) is 6.9 L/100 km, so chances are that my After Reset screen would be reading 6.9, 7.0 or at the absolute most, 7.1 if I had never reset it.
I also went through the fills I've done with OBC results recorded (again, 8000 km and rising) and found that there is exactly a 0.4 L/100 km optimism to the OBC reading.
You can check this for yourself by clicking on my fuel economy logo for the B 200 in the signature line. The OBC result is shown in the right-most column, under "BC", which will show the result if you hover your cursor over it.
Old 03-12-2008, 03:04 PM   #47 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Just to confirm tank capacity B class brochure states:-
"Tank capacity(L/of which reserve approx) 54/6 "
This is shown for all variants of the B from B 150 - B 200 Turbo & includes Diesels.
Hope that clears up any misunderstandings.
kdbcom is offline   Reply With Quote
Old 03-12-2008, 06:43 PM   #48 (permalink)
nest18's Avatar
Mike,
I did have the same 0,5l/km optimistic figure from the the computer vs real measurement ...
Daniel
Old 03-13-2008, 07:52 AM   #49 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
You're right Mike! I'm not in the game. Life is too short.
Let's play my game for 6 months and not reset the "inaccurate" B fuel estimator.
Cheers, Derek
Old 03-13-2008, 07:56 AM   #50 (permalink)
Mike Tee's Avatar
Nope, it would only embarrass you. My average over the past few tanks is well under 7 L/100 on the lying and cheating car's OBC.
Fuel consumption Bob M R170 SLK Class 4 12-21-2006 03:57 PM
fuel pump affecting fuel consumption? rich369 W140 S-Class 0 11-22-2006 08:32 PM
Too Much Fuel Consumption Dan AKaenyi General Mercedes-Benz 3 10-02-2006 02:38 PM
Help Removing Fuel Tank Fuel Screen JohnMcConnell W123 E,CE,D,CD,TD,TE Class 24 09-08-2006 06:06 AM
fuel consumption Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 01-03-2002 10:07 PM
