Old 09-27-2007, 10:21 PM   #1 (permalink)
jtcb's Avatar
Date registered: Apr 2007
Question Bugs get into the car from front grille
My workplace is in a rural location. There are trees on the parking lot. I notice almost everyday either rain or shine that there are a few flying bugs in the car. They are small bugs. How do they get into the car? All windows are up when parked. The only way I can think of is the front grille. Is it possible? Is there any solution to that?
jtcb is offline   Reply With Quote
Old 09-28-2007, 02:14 AM   #2 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
I would think that is unlikely as most in cars I think you will find the bulkhead seals the engine bay from the passenger compartment (even the cables go through rubber grommets)
The more likely route for your critters is probably through the air ventilation system. You could try changing to the recirculatory position before parking. As this is supposed to stop 'polluted' air from geting in (ie fumes from traffic in front) it should in theory stop your insects. In theory the pollen filter should stop them though.
However there must be air vents out of the back of the car (in the normal ventilation mode if fresh air comes in the stale must go out somewhere) and they could possibly be coming in here.
Are they the same type of bugs all the time if so could they have got in on some occasion & nested (or whatever insects do).
Try the ventilation switch option first & let us know how you get on
kdbcom is offline   Reply With Quote
Old 09-28-2007, 07:22 AM   #3 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Check the fit of your pollen filter. You have to remove the black plastic cover between the front wipers to access it. It's somewhat flimsy and might not be sealing properly. Derek
Old 09-28-2007, 07:51 AM   #4 (permalink)
jtcb's Avatar
I was thinking about the air vent from the front. Is it the recirculate button you are talking about kelvin? I thought it is only on when the engine is on. During hot summer days I set the fan to blow air front the front. You know the arrow pointing to the seat? In winter I switch it to blow air onto the window.
Are there air vents in the back for air to go out? I never thought of that. I thought when fresh air comes in, they are there to stay. I know there are vents for the two small back wing windows. They are there to clear the fog only?
Old 09-28-2007, 08:53 AM   #5 (permalink)
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Send a message via Yahoo to Mike Tee
The vent in the rear must have a flap on it that remains closed unless there is positive pressure in the cabin.
2008 Mercedes-Benz B 200
2005 smart fortwo cdi pulse cabriolet, loaded
1966 Peugeot 404 Coupé Injection
1989 Peugeot 405 DL, 366,000 km
Mike Tee is offline   Reply With Quote
Old 09-28-2007, 09:11 AM   #6 (permalink)
kdbcom's Avatar
Yes it was the recirculate button I was thinking of but re reading the on-line owners manual it looks like it is an electrical switch & may well reset when you turn the car off. (usually they are a manual turn switch that physically block off the outside air M/B must do this electrically somehow).
There must be somewhere for the air to get out otherwise the pressure inside would build up to an enormous degree. To get a flow of air you have to have an air inlet & outlet, thats simple physics. Saying that I've just looked all round the back of mine & I could not see any air outlets. Any one any ideas
Old 09-28-2007, 06:14 PM   #7 (permalink)
We need detailed pics of all vents on the car. That probably would be very hard for George to pull out of his info on the B. It also would be very nice if some service rep could do the same, and set us straight on how the ventilation system works. I must admit, I've seen a lot of cars apart and I've never seen an exit for ventilation but then again I've never really been looking for it either. I also live in a rural setting which is full of bugs in the spring but they're never ever in the B.
Old 09-29-2007, 01:48 AM   #8 (permalink)
Mike Tee's Avatar
FWIW, on the Peugeot 405, the vent is in the trunk (boot) flloor on one side, behind a wheel actually (and behind the trunk trim panel); it vents to the underside of the car and has an anti-exhaust fume (and bug!) flap on it (which closes when there is neutral pressure in the car).
I imagine it's in some similarly obscure location in the B.
Old 09-29-2007, 03:05 AM   #9 (permalink)
kdbcom's Avatar
On some cars I've had the vent is in the rear quarter panels (between the rear door & the rear window) under a fluted plastic trim. The B is appearing to be quite a mystery.
Old 09-29-2007, 08:03 AM   #10 (permalink)
gsp1's Avatar
Date registered: Aug 2006
Vehicle: B150+Sports
Hi there, as far as i searched in the service manuals i didn't find any specific info for air outlets driving the air out of the car... Only the IN section is described which as all we know is from the front dust filter and is fed into the car from the internal air vents depending on the settings of the controls....
gsp1 is offline   Reply With Quote
Front Grille My04230k W220 S-Class 9 04-01-2007 10:54 PM
Car covers/Bugs Kiran R171 SLK Class 6 04-11-2006 11:02 AM
Front Grille Arold R171 SLK Class 1 11-12-2005 08:42 AM
Front Grille kingkong777 W123 E,CE,D,CD,TD,TE Class 2 11-10-2005 11:35 PM
Front grille e320mule W210 E-Class 3 03-09-2005 10:25 AM
