I have the new K&N air filter. But, I do not know where the air filter is located so I can replace it with the K&N. Can someone help by telling me where to look. Pics would help.
Hi i don't know if 200T has different shape but in smaller models the air filter is located under the engine's cpu unit, which is a silver box on the top of the engine next to the intakes. You have to unscrew two "philips" screws and open this case. Under this you'll find the air filter..
HI George and thanks again for the pics. In the B200, that's exactly where the air filter is. Just like the oil filter, many things are hard to find! Derek
Is that the air filter for the air con? I thought it is at the front where the grille is.
No, this is the air filter of the engine. The aircon filter is at the down end of the windshield under a plastic cover which opens by hand.
On the pictures i attached, you can see this cover exactly over the "4a" label on the middle picture...
