Old 09-07-2007, 10:13 PM   #1 (permalink)
jtcb's Avatar
Date registered: Apr 2007
Unhappy Tire wall has peeling effect
How do you check if the tire pressure matches the recommended numbers on the fuel cap? The front pair doesn't look right to me now. They look bulge when parked. Also, I notice there is some peeling effect on the tire wall of the front left tire if you know what I mean.. The peeling effect is on the circle surrounding just above the word Michelin. I will take actual pic later. The peeling is very noticeable. It is less noticeable on the rear left, rear right, and almost none on the front right. The car is one year old now and I have never check the pressure since took delivery. If you are in Canada with standard 16" tire and rim, Michelin should be the brand you have.
To give you an idea what I mean, look at the sample pic below. Peeling effect area is on the red.
jtcb is offline   Reply With Quote
Old 09-08-2007, 12:47 AM   #2 (permalink)
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Send a message via Yahoo to Mike Tee
Buy a tire pressure gauge!
Maybe you have 100 PSI in your tires and they are about to explode! Seriously, check the pressures and then contact Michelin about this peeling you refer to. Have you been dragging the tires along concrete kerbing?
2008 Mercedes-Benz B 200
2005 smart fortwo cdi pulse cabriolet, loaded
1966 Peugeot 404 Coupé Injection
1989 Peugeot 405 DL, 366,000 km
Mike Tee is offline   Reply With Quote
Old 09-08-2007, 04:22 AM   #3 (permalink)
jtcb's Avatar
I don't think so because the tire doesn't look to have enough pressure. The peeling is on the left hand side so I don't think it has anything to do with dragging the tires along concrete kerbing.
Old 09-08-2007, 08:13 AM   #4 (permalink)
The first question is easy to answer. You check the tire pressure with a tire pressure gauge. Barring that go to a full service gas station at your next fill up and have the attendant check the pressure.
The second question sounds very serious. A tire that is coming apart the way you describe down to the threads is a disaster waiting to happen. If you're only talking about a superficial peeling like a thin veneer (think clearcoat paint) then it may simply be some residue left over from something you drove through.
Definitely take pictures and post them up. If it looks severe then get it taken care of right away.
santiago0000000000 is offline   Reply With Quote
Old 09-08-2007, 09:27 AM   #5 (permalink)
jtcb's Avatar
Here is the pic with peeling effect on the tire. It is not my tire.. It is from another member from the C-class forum.
Old 09-08-2007, 10:04 AM   #6 (permalink)
That looks very serious. I think Continental and/or Mercedes-Benz needs to be contacted ASAP.
Given the PR nightmare that Firestone/Ford went through not too long ago, I am sure they want this taken care of right away.
Actually, didn't you say you had Michelins? The pic is of a Continental tire and my wife's Canadian B200 has Continentals on it as well.
Either way, keep us in the loop.
Old 09-08-2007, 10:30 AM   #7 (permalink)
jtcb's Avatar
Your wife's B have Continental tires? Mine are Michelins.
Now what should I do? Do you think contacting my dealer help? Do you think they will replace the tire at no cost? The car is a year old now. I haven never check tire pressure since took delivery. Could the tires been under or over inflated already on delivery? What causes the peeling? What ground do I have?
Old 09-08-2007, 11:57 AM   #8 (permalink)
Yes, we took delivery last May and the car came with Continentals.
I don't think over-inflation would cause the casing to separate like that. Typically an over-inflated tire will cause more wear down the center of the tread but obviously anything is possible.
Have the tire pressures checked and take a picture of your tire, espeically a closeup where you can see the threads showing.
Bring it to the attention of your dealership and ask them about it. Mention that you've seen evidence of this occuring on other Mercedes and to ask if there is some kind of safety recall/notice on the tires. If they do nothing then escalate to MB Canada and Michelin Canada.
What mileage do you have on the tires? I don't know if you took them off during winter but I'm curious to know what kind of mileage you have on the tires.
Old 09-08-2007, 11:59 AM   #9 (permalink)
Date registered: Apr 2006
Vehicle: B 200 Turbo CVT 2006, GL 320 CDI 2008
Your tires are almost worn out go and buy new tires and check your alignment.
Driving with thess tires on the water might be very slippery I can see you are already on the minimum thread.
Buy Tires recommended by the dealer do not buy the same one get other brand but still approved by Mercedes because of warranty issues.
How many km did you done on these tires?
B200 Turbo 2006
Comet Grey, CVT, Premium Package, 17" wheels10 spoke
Harman Kardon sound system, 10 Way power front seats manually adjustable steering 4 way.
GL 320 CDI 2008
Sanidine Beige, Cashmere beige leather sets, RSE, Premium Package, BI Xenon Package, Rear Climate Package, Distronic, Running board, Keyless Go
B200Turbo is offline   Reply With Quote
Old 09-08-2007, 12:57 PM   #10 (permalink)
Mike Tee's Avatar
Those C-Class tires may be showing evidence of major wheel alignment problems (excessive toe in, possibly also positive camber) and are worn well beyond reason. This wear could also be from overly-ambitious cornering.
I asked about kerbing because where I live there are plenty of opportunities to parallel park on the LH side of the road (one way streets).
Cause and effect.. shrimpton Off-Topic 3 10-07-2006 08:28 AM
SLK 55 Side wall by tire... fybarra R171 SLK Class 0 04-27-2005 11:29 PM
Tire Size and Its Effect on Bearings Phil G-Class 4 03-17-2005 01:25 AM
Discount Tire employee warned me about Kuhmo's notorious reputation for side wall bubbles.... dbottoms R170 SLK Class 1 04-19-2003 11:53 PM
tire plugged on clk 430..effect? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 06-20-2001 05:06 AM
