Old 08-26-2007, 12:23 AM   #1 (permalink)
gsp1's Avatar
Date registered: Aug 2006
Vehicle: B150+Sports
Brake Fluid replacement
In case that someone is interested in replacing the brake fluid my himself here is the procedure. The only problem (as they do for the oils also) is that they use somekind of pump to extract the old fluid? If someone has done this procedure please let us know details... thanks
gsp1 is offline   Reply With Quote
Old 08-26-2007, 09:07 AM   #2 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Originally Posted by gsp1
In case that someone is interested in replacing the brake fluid my himself here is the procedure. The only problem (as they do for the oils also) is that they use some kind of pump to extract the old fluid? If someone has done this procedure please let us know details... thanks
Thanks for the info. The pump removes the old brake fluid to save time in pumping through the old oil to get to the new brake fluid. Another way is to suck as much brake fluid as possible out with a"cooking baster"( It's a rubber capped tube that sucks cooking juices out.)Your diagrams show AR #'s beside different models(ie: *BF42. 10-P-1001 01E) on the right side of the page. There might be more info with these other pages. I've bled many brakes and it's quite simple but with ESP & BA , you probably have to check a few things first to make sure all is OK. Here in North America small hydraulic jacks are available for single wheel lifting and removing. cost approx. 30 - 80 $ CDN. I hope they're available in Greece. If your not using the pump, then you need a helper to manually pump the new brake fluid through the lines. If you want great pics of how to do it, go to" Audiworld.com" > resources, >tech articles,> brakes& suspension. Their tech articles are the best ever and explained with humor. I wish I had their talent at explaining things.
\George , we will talk some more. Thanks again, Cheers, Derek
Old 08-27-2007, 12:47 AM   #3 (permalink)
gsp1's Avatar
Derek hi, thank you very much for this useful info as i haven't replaced again brake fluids. Also my car has 1 year more (in the manual states every 2 years). But i'll keep this info for when i need it.. Of course we will have a lot to discuss!
Cheers!
trans fluid and diff fluid replacement cost? numitor R170 SLK Class 10 07-28-2007 10:40 PM
does flushing brake fluid help the brake pedal feel firmer & stop faster? ProV1x General Mercedes-Benz 13 07-09-2007 11:58 PM
replacing rear pads and brake fluid, and tranny fluid,... ewalberg G-Class 3 03-25-2005 10:15 AM
HELP ! Just replaced pads myself ...... need brake advise ..... & brake fluid zuzu W163 M-Class 12 05-23-2003 04:36 PM
Is a brake fluid flush & replacement supposed to be part of the B service?... Daniel W163 M-Class 7 03-20-2003 08:44 PM
