Old 02-05-2008, 04:08 AM   #31 (permalink)
gsp1's Avatar
Date registered: Aug 2006
Vehicle: B150+Sports
Hi to all that have the same 'ticking' sound from the steering system...
Just today i called them back asking for any progress for this case... For my surprise they informed that they will have to change the rack&pinion completely to fix this problem.. I am expecting new call for having the car there...
I hope that first my problem will be solved, and second.. my car will continue to go straight!!!!
I hope also, that these guys should follow step by step instructions as WIS says because there are many specifications as for the force that screws are tightened , for safety bolts that is for one use only ... etc...
So if anyone has the same problem and has no info from his dealer its time to search for it..
Cheers
gsp1 is offline   Reply With Quote
Old 02-05-2008, 09:02 AM   #32 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
George,
To make sure that all is completed to your satisfaction, make a request to see all parts that are changed during this repair including those "once only" nuts and bolts.
Bring your camera and take pics of all the changed parts.
Together,we'll study our WIS notes and our great team here will review what they did and hopefully help you out.(if necessary)
Good luck, Derek
Old 02-05-2008, 01:16 PM   #33 (permalink)
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Send a message via Yahoo to Mike Tee
Originally Posted by Derek Lecours View Post
George,
.....parts that are changed during this repair including those "once only" nuts and bolts.
I recently informed a long-time Peugeot mechanic that I only know online that the head bolts on a 405 are "once only". He didn't know that and looked a bit stupid to the other forum members......I wonder how the cars he repaired with re-used head bolts are faring
2008 Mercedes-Benz B 200
2005 smart fortwo cdi pulse cabriolet, loaded
1966 Peugeot 404 Coupé Injection
1989 Peugeot 405 DL, 366,000 km
Mike Tee is offline   Reply With Quote
Old 02-05-2008, 01:22 PM   #34 (permalink)
gsp1's Avatar
George,
Good luck, Derek
Thanks Derek, probably i will follow your advise and publish these pictures here..
Old 02-05-2008, 06:09 PM   #35 (permalink)
Oshawa_B200T's Avatar
Date registered: Feb 2008
Vehicle: B200 Turbo
Originally Posted by bestjsg View Post
I have this kind of noise also, in fact I can feel it ticking when I hold the steering wheel. It happens mostly when the engine is cold or from cold to warm, and the problems go away after I switch off the car and start again, that's why when I was at the dealership I can't show the problme/noise to the mechanic at all. ...
In the morning when I first start the car, it would chok and the rpm point flickers between 700rpm and 1000 rpm and it sounds like the car is going to stall or something , but so far it never stall but just choking, however, when I put it in D gear this flicking pointer thing goes away while the cracking noise from the steering sometimes being heard again not often and can't repeat at dealer....so frastruting....
Finally, someone with the EXACT same problem as me! I have brought it to my dealer 3 times and they could never recreate the noise. Meanwhile it's getting louder and louder. So far I see no correlation to warm or cold, but when I change direction I hear it BUT when I hit the breaks, the noise stops for a bit (10 seconds) and then comes back. Is it the same for you as well? I tell you this car is beginning to be a POS IMO!!!
Car history:
1983 VW Rabbit Diesel
1987 VW Golf GTI
1993 VW Golf GL Diesel
1997 Audi A4 Quattro AWD
2001 BMW 325xi
Oshawa_B200T is offline   Reply With Quote
Old 02-21-2008, 10:37 PM   #36 (permalink)
bestjsg's Avatar
Date registered: Sep 2007
well I am taking it in again next Wed....this time I will leave it over night and see if they can find the problem or at least hear the clicks.....wish me luck......but honestly...WTF...we are talking about a Mercedes here....
2008 Benz B200 Turbo w/ Premium Package White
2005 Toyota Sienna CE (POS...breaking lease to get the benz)
1996 Dodge Stratus (great car first repair on it's 5 th year)
bestjsg is offline   Reply With Quote
Old 02-22-2008, 01:25 AM   #37 (permalink)
gsp1's Avatar
For info: my rack&pinion part just came and finally my car is programmed for replacement on this Tuesday... i hope they will fix it and this noise stops...I will bring some photos here as soon as i finish with this case!
Cheers
Old 02-26-2008, 07:39 AM   #38 (permalink)
gsp1's Avatar
Hi to all... FINALLY i have some real results here...
Before some minutes i took my car back.. i have to say that seems to drive straight again! The feel of the steering wheel seems to be exactly the same and the good point is that i cannot hear this f....ing noise any more... i hope this will last!.. Here is also the photo of the replaced part.. (the safety screws are on the body but not seen in the photo) and the other good point is that they replaced the whole unit including the motor part, because in WIS its described as rack & pinion only without the electric motor unit.. Of course it needs more testing which i will post here as the days pass... Finally they gave me a paper with all the adjustments (camber,caster, toe) that they made...
Cheers
Old 02-26-2008, 09:54 AM   #39 (permalink)
George,
That's great news and let's hope that they got it right.
Imagine the cost of changing that without a warranty!!
Good Luck, Derek
ps: Keep a close eye on the wear of your front tires.
Old 02-26-2008, 10:49 AM   #40 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Good news George, keep us informed if you get any further problems with it
kdbcom is offline   Reply With Quote
Steering Wheel Noise Justsaymo01 W210 E-Class 1 01-09-2007 04:42 AM
Scraping noise in steering wheel? DaveMck W140 S-Class 5 12-12-2006 10:36 AM
Steering wheel noise bigbillybob991 W126 S,SE,SEC,SEL,SD,SDL Class 36 05-10-2004 05:25 PM
NOISE FROM THE STEERING WHEEL Chucky300 W220 S-Class 0 01-11-2004 06:40 PM
noise in steering wheel COOPER W124 E,CE,D,TD Class 1 01-16-2003 11:34 AM
