Old 08-09-2007, 01:15 AM   #1 (permalink)
Date registered: Jul 2007
Vehicle: B-180 cdi with Sports pack and Comand Aps
Question Cruise control kit
Hi.
This is my first post on the forum which i find excellent,my vehicle has just about everything but not cruise control which my previous vehicle had,i do miss it and would like to know if there is a kit which i can buy to fit myself.
satking is offline   Reply With Quote
Old 08-09-2007, 02:21 AM   #2 (permalink)
deheld's Avatar
Date registered: Jun 2007
Vehicle: W245 B-Class 180 CDI
Hi,
Yes. I've read on a german forum that it's possible to retrofit the cruisecontrol and speedlimiter. Two things need to be done, the control stalk needs to be fitted, and the computer needs to be told that the cruisecontrol is present.
Here's the bill with partnumbers.
18 AW.........................................96,30
A169 462 02 23 Verkleidung.......10,30
A169 540 33 45 Reparatursatz...10,52
A169 545 00 04 Schalter.............65,11
Q1230000 Kleinmaterial..............15,00
Endbetrag (inkl. MwSt.).............228,79 Euro's
Since installing the stalk involves removing the airbag I recommend that this is done by qualified mechanics......
More info in German:
www.b-klasse-club.de • Thema anzeigen - Tempomat-Nachruestung
Good luck !!!
deheld is offline   Reply With Quote
Old 08-09-2007, 03:30 AM   #3 (permalink)
Ikelos's Avatar
Date registered: Aug 2006
Vehicle: B 170se with sports pack.
Send a message via Skype™ to Ikelos
when I got my 2006 B class, I was told the cruise control was standard on all models, strange it is not on yours
Ikelos is offline   Reply With Quote
Old 08-09-2007, 06:43 AM   #4 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
I think they probably meant standard on all auto models. I read somewhere that 90% of M/B are autos.
kdbcom is offline   Reply With Quote
Old 08-09-2007, 07:39 AM   #5 (permalink)
Hi Deheld
Do i understand that what you are saying is that the vehicle is pre wired and you just nead to fit these items.
Old 08-09-2007, 09:22 AM   #6 (permalink)
Ikelos's Avatar
kdbcom, i guess you are right, they must have meant Autos
with the parts needed and the work to fit them, it sounds like it will cost a arm and a leg.
Old 08-10-2007, 02:24 AM   #7 (permalink)
deheld's Avatar
Originally Posted by satking
Hi Deheld
Yes, that is what I understand from the german forum. Makes sense, since the throttle is controlled via a fly-by-wire construction you basically only need the stalk and the adjustment in the computer.
My previous Audi was also pre-wired, it's often cheaper to retrofit the cruisecontrol than to order it from the factory.
Old 08-13-2007, 03:10 AM   #8 (permalink)
Originally Posted by deheld
Hi,
Good luck !!!
Sounds, interesting, I'm hoping to install the cruise control on my B200 CDI. Mine is auto but it is not a standard option, it is optional..
Can someone please explain what is this part number?
i thought it should be something like a A169 xxx xx xx
sta0880 is offline   Reply With Quote
Old 08-13-2007, 03:51 AM   #9 (permalink)
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
Hi,
It is very simple if done by a professional. I presume that 18AW is work units and the labour fee. It can be done in one hour.
Modz ... enjoy the difference. www.benzmodz.com
miroj is offline   Reply With Quote
Old 10-30-2007, 04:59 PM   #10 (permalink)
nest18's Avatar
Date registered: Oct 2007
Vehicle: B200 - 2007
Hi Guys,
My b200 did not came with a cruise control, but I would like to get it retrofit. Had anyone got it done ? The dealership is kinda not calling me back about this.
thanks
nest18 is offline   Reply With Quote
Cruise control display question. Does you car display the cruise control speed in the lower display? aquascape R171 SLK Class 42 01-15-2006 02:37 PM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 10:51 PM
cruise control JamesDean W126 S,SE,SEC,SEL,SD,SDL Class 1 05-15-2005 08:47 PM
cruise control willy58 W124 E,CE,D,TD Class 0 08-19-2004 05:08 PM
Fitting Cruise control to a non-cruise car - Is it possible? ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 2 08-08-2004 10:34 AM
