Old 07-31-2007, 06:47 AM   #21 (permalink)
jtcb's Avatar
Date registered: Apr 2007
Originally Posted by Sebl
The feature that jkalpin refers to is slightly different to this. The cluster can also be programmed to show not only the Km's remaining but also the amount of fuel left in the tank in litres. I had Miroj do the programming on my vehicle to activate this feature.
Sebl
Can you tell me how to program it to show litre of gas remaining?
Speaking of ThermoTronic, I don't know if the Canadian B has it or not.. I notice there is a small vent thing near the air conditioner switch. What is it for?
jtcb is offline   Reply With Quote
Old 07-31-2007, 07:41 AM   #22 (permalink)
adamlynn's Avatar
Date registered: Jul 2007
Vehicle: W203, W210, B200
neat stuff
2007 B200 TURBO
2006 C280 4MATIC
1997 E420
adamlynn is offline   Reply With Quote
Old 07-31-2007, 10:09 AM   #23 (permalink)
StGermain's Avatar
Date registered: Oct 2005
Vehicle: B 180 CDI
There is another small vent between the bulbs on the ceiling. They both have a misterious purpose.
It would be really kind if Miroj could tell us what to change in the computer in order to show the litre of gas.... Thanks in advance!
StGermain is offline   Reply With Quote
Old 07-31-2007, 10:20 AM   #24 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Originally Posted by miroj
Tunnel Mode (as above) is dormant on some cars.
It is operational on the latest UK B 200 CDI
Has any one worked out if the air con is on or off by default as on my old B (and the dealer told me this) it seemed to go off when you pushed the button and the red light came on (ie on by default ) but on the new car it seems that sometimes its on when you push the button and red light comes on yet other times it seems to be the other way round . Its almost as if it toggles from one mode to the other. Weird !
kdbcom is offline   Reply With Quote
Old 07-31-2007, 11:02 AM   #25 (permalink)
deheld's Avatar
Date registered: Jun 2007
Vehicle: W245 B-Class 180 CDI
The thermotronic is the electronically controlled ac. Where you set a temperature using a up and down arrow, it has a little display. The one with the three wheel thingies is a ac but no thermotronic.
The slits in the thermotronic controls are for measuring the cabin temperature. After all you set the inside temp, so the car has to measure this.
The slits on the roof are where the microphones for the (exceptionally good but expensive) carkit are located.
deheld is offline   Reply With Quote
Old 07-31-2007, 11:04 AM   #26 (permalink)
deheld's Avatar
Weird as it sounds, this is different on some models. So what you see is true.
The easy way is remembering that when you demistify the front window using the special defog key, the AC is always turned on. So, just press the button and look if the light goes on or off.
Old 07-31-2007, 02:19 PM   #27 (permalink)
Ikelos's Avatar
Date registered: Aug 2006
Vehicle: B 170se with sports pack.
Send a message via Skype™ to Ikelos
Hi, I think I have lost the plot, which button (key) is the defog one. thanks
just tried closing all the windows with the recirculate button thingy and it works a treat,
we live and learn..
Ikelos is offline   Reply With Quote
Old 07-31-2007, 06:29 PM   #28 (permalink)
jtcb's Avatar
Is the recirculate thing not available in the Canadian version? I have no idea what you guys are talking about..
Old 08-01-2007, 01:00 AM   #29 (permalink)
Ikelos's Avatar
Between the 3 rotary knobs which control the air con and so on, there are a couple of buttons, one has a picture of a car on it with a curved arrow on it, that is the recirculate thingy.
Old 08-01-2007, 10:48 AM   #30 (permalink)
trout's Avatar
Date registered: Jul 2006
Vehicle: B Class 200SE
When the a/c is on the red light above it is alight on the [B]thermotronic[/b]
why you can switch the aircon on and off is probably to save fuel.
|Although just back from south of france and the petrol consumption did not seem too bad with it on in temps 35 degree C
trout is offline   Reply With Quote
Hidden Gems on the E Class (Features most not aware of) bpinto W211 E-Class 105 01-16-2008 11:30 PM
features you wish were available... kernith W211 E-Class 26 07-18-2007 12:19 AM
Features PFitto W164 M-Class 26 01-04-2006 12:19 PM
What one or two features do you wish your ML came with?? Ratso W163 M-Class 15 01-22-2004 12:09 AM
Hidden features whiteyford W208 CLK Class 10 12-25-2003 11:57 AM
