Good ideas of hidden storage space Keith. I didn't know you can pull the liner out in the first pic. There is also some space under the rear seat if you want.
Does anyone have the part number for the plastic cover for the right hand side "secret compartment" behind the rear seatback? And is there a liner for that on the 2005 models?
I understand that some versions of WIZ have a parts number catalogue in them, perhaps, if some one has this version they could let us know that cover number.
Thanks for that info Jeffery that is quite a useful space under there & I will be needing every cubic inch / cm when going away this year.
Mike, Keith,
I'm sure the dealer could get you the right side cover and inner liner by looking in the 06 parts.
Long ago Keith said he saw a depression that showed where the right hand side should fit. If you feel that they haven't changed the shape from 06, then it should be an easy install.
Good luck, Derek
