Old 07-24-2007, 12:53 PM   #1 (permalink)
A.N.'s Avatar
Date registered: Apr 2007
Vehicle: 06 White B200T
Tire Pressure.
Just curious if anyone has found a good pressure for the tires, I've been using the recommended 30 psi (front) and 33 psi (rear), but I find my front tire squeal when cornering tight on certain pavement or easy of the line on hard acceleration. They seem to have a lot of tread left, It's kinda weird!
Anthony
A.N. is offline   Reply With Quote
Old 07-24-2007, 02:23 PM   #2 (permalink)
Ikelos's Avatar
Date registered: Aug 2006
Vehicle: B 170se with sports pack.
Send a message via Skype™ to Ikelos
Must be different where you are, here the correct pressure on all tires are 29.
except when the car is fully loaded, 5 people and luggage.
Ikelos is offline   Reply With Quote
Old 07-25-2007, 12:55 AM   #3 (permalink)
deheld's Avatar
Date registered: Jun 2007
Vehicle: W245 B-Class 180 CDI
My car uses the 205 tyres standard on the B180CDI.
MB advises 2.0 bar front and rear, that would equal to 29 PSI. That provides a very smooth and silky ride, but the tyres squeal when turning and they have that empty look, they bulge at the bottom.
Last month after the car was serviced at the dealer they adjusted the tyres to 2.2 bar or 32 PSI. This still provides a good ride (somewhat less smooth) but stops squealing and bulging.
I have tried 2.4 or 35 PSI but that makes the car too bumpy.
My wintertyres (195 ones) are always at 32 PSI, since they have a softer body.
deheld is offline   Reply With Quote
Old 07-25-2007, 04:57 AM   #4 (permalink)
Date registered: Jul 2006
Vehicle: Brabus B200T
On the 19" rims 36psi is the recommended pressure for the tyres. Ride isn't too bad, am using nitrogen in the tyres.
Sebl is offline   Reply With Quote
Old 07-25-2007, 10:50 PM   #5 (permalink)
yuna_ronald's Avatar
Vehicle: B200 Turbo
is 32PSI for both front and rear??
yuna_ronald is offline   Reply With Quote
Old 07-26-2007, 03:37 AM   #6 (permalink)
Date registered: Mar 2007
Vehicle: B200 cdi SE with Sports Pack
Anthony
I guess that the tyre pressures will vary from model to model depending on tyre and wheel size. I just go by the guide on the inside of the fuel filler cap. This may also differ from country to country.
I'm currently running on 36 psi all round, with 215x45x17 tyres.
Regards
Ross.
norfolk.enchance is offline   Reply With Quote
Old 07-26-2007, 03:28 PM   #7 (permalink)
Ikelos's Avatar
does the filler cap lid on yours say 36 all round....................
Old 07-30-2007, 08:51 AM   #8 (permalink)
Yep, sure does. 36 psi all round for normal capacity. 36 front 38 rear for a full car load.
Ross.
Any luxury car can make you look like your going places, but with a Mercedes Benz you have already arrived.
Old 07-30-2007, 10:33 AM   #9 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
MY B recommends 29 & 29 normal and 30 & 33 at maximum load as per the gas cap. As you change rims and tyres, you have to adjust your pressure accordingly, and sometimes it's trial and error. With those super tyres and wheels, (like Sebl and others have) you now have to be so careful with potholes and just basic little curbs, and they do demand a lot of increased pressure just to protect those low sidewalls. But they do look beautiful. Cheers, Derek
Old 10-14-2007, 07:06 AM   #10 (permalink)
paul001's Avatar
Date registered: Jun 2006
Vehicle: B-Class 180 CDI
I have just adjusted tyres to 35 PSI. Earlier they were 29 PSI and I wasnt happy with that ride. now the ride is a bit harder but considerably pleasanter. you feel more control over the car
paul
paul
paul001 is offline   Reply With Quote
tire pressure BBALLER14 W220 S-Class 1 06-19-2006 08:07 AM
taking down tire pressure for 4x4 ing. could you do that on a low profile tire? blau The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-06-2006 02:49 PM
Tire pressure AlanS The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 05-10-2004 12:18 PM
TIRE PRESSURE woodyww W163 M-Class 7 05-19-2003 07:55 PM
Tire pressure qb320 W208 CLK Class 0 11-16-2001 01:46 PM
