Old 07-03-2007, 09:26 PM   #1 (permalink)
A.N.'s Avatar
Date registered: Apr 2007
Vehicle: 06 White B200T
Best Gas !!!
Hey does anyone in Canada have any advice on which company has the best gas for the B? I use Husky and their 94 Octane (ethenol blend). Is Shells V-Power better, no ethenol but 91 Octane? I think Chevron and Petro Canada have 94, but they only seem to sell it in Vancouver and Montreal, why? Any ideas?
Anthony
A.N. is offline   Reply With Quote
Old 07-03-2007, 10:10 PM   #2 (permalink)
jtcb's Avatar
94 is the highest available I think. Only PC and Husky/Mohawk sell 94. Why do you fill 94 though? The min. requirement is 91 for the B. I only fill 91.
jtcb is offline   Reply With Quote
Old 07-03-2007, 11:05 PM   #3 (permalink)
yuna_ronald's Avatar
Vehicle: B200 Turbo
hey... my dealer said petro canada's gas is the best... and esso is the worst...
but i am not really sure.... cause a lot of ppl said shell and sunoco are the best...
yuna_ronald is offline   Reply With Quote
Old 07-04-2007, 01:13 PM   #4 (permalink)
Misfit's Avatar
Date registered: Nov 2005
Vehicle: '06 B200, '05 Smart
Most come from the same refineries anyway - I just stickwith 91 (although Iwon't use Ma & Pa stations 'cause Ihave no clue if the 91 label on the pump is not pointing to an 87 tank in the ground !
Misfit is offline   Reply With Quote
Old 07-11-2007, 09:58 AM   #5 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Don't worry about 91 or 94 octane unless you're in a race car. Worry more about bad gas from an old tank or water in their tank. Remember it's Canada(+35 C to - 40 C) and that can cause condensation in any tank or reservoir and there's very little we can do about it except add the gas line antifreeze additives at the appropriate times. Cheers, Derek
Old 07-11-2007, 02:10 PM   #6 (permalink)
Misfit's Avatar
http://www.benzworld.org/forums/gene...light=top+tier
Old 07-17-2007, 12:46 AM   #7 (permalink)
n0alpha's Avatar
Date registered: Mar 2004
Vehicle: Silver 1994 C280
Since the ownership of gas companies has been consolidated as such:
Chevron = Texaco = Shell
BP = Arco = 76 = ConocoPhillips
Exxon = Esso
...I don't pay much attention to which gas station I buy gas at, but rather I look purely at the price. When it comes right down to it, gas at different stations comes from the same refineries, so it really doesn't matter where you buy your gas. Just get the right grade, which is 91 octane or higher.
Silver 1994 C280
125,000 miles
Mercedes: Time-tested engineering, timeless styling.
n0alpha is offline   Reply With Quote
Old 11-07-2007, 05:00 PM   #8 (permalink)
Bill F's Avatar
Date registered: Oct 2007
Vehicle: B 200 Turbo 2007 SAAB 9000
Anthony
Hi
Came across this thread and have a few thoughts on Husky/ Mohawk ethanol gas. (sold only in Canada). Used it for a while in my SAAB (needs 91 octane) and found fuel consumption to increase. Talked to owner at gas station and he agreed that a few cars did have poorer performance and higher gas usage.
SAAB dealer said to stay away from any ethanol blends.
Mechanic recommends not using ethanol in any Mercedes car. I use Chevron 92 octane but suggest using any top tier fuel.
Top Tier Gasoline
"TOP TIER Detergent Gasoline is the premier standard for gasoline performance. Six of the world's top automakers, BMW, General Motors, Honda, Toyota, Volkswagen and Audi recognize that the current EPA minimum detergent requirements do not go far enough to ensure optimal engine performance."
Not sure if other nations have similar standards but I would find out.
The difference in price between discount gas and a branded gas is only a few cents a liter, why take a chance?
Bill
Bill F is offline   Reply With Quote
Old 11-07-2007, 05:53 PM   #9 (permalink)
jtcb's Avatar
Are you sure about that? Which Husky and MB mechanic did you talk to? I have been filling Husky's 92 Octane for a while now. I find it has the cheapest price/high octane. The car's minimum requirement is 91. I have never fill 94.
Old 11-07-2007, 08:12 PM   #10 (permalink)
Bill F's Avatar
Delta gas station (highest price for gas in area), and Richmond dealer.
Ironically BCAA (car club) offers a discount for Husky/Mohawk, but when I needed onsite service (not for MB) and offered coupons for gas, the mechanics from the auto club stated they did not use Husky/Mohawk but used Chevron fuel in their personal vehicles.
The following is a quote from Wikipedia, the free encyclopedia
"Fuel economy
All vehicles have a fuel economy (measured as miles per US gallon -MPG- , or liters per 100 km) that is directly proportional to energy content.[30] Ethanol contains approx. 34% less energy per unit volume than gasoline, and therefore will result in a 34% reduction in miles per US gallon.[18][19][20] For E10 (10% ethanol and 90% gasoline), the effect is small (~3%) when compared to conventional gasoline,[31] and even smaller (1-2%) when compared to oxygenated and reformulated blends.[32] However, for E85 (85% ethanol), the effect becomes significant. E85 will produce lower mileage than gasoline, and will require more frequent refueling. Actual performance may vary depending on the vehicle."
Still recommend a Top Tier fuel
Bill
Running on empty Hit by high prices and fees, some gas stationowners stop selling gas Jakarta Expat Off-Topic 1 05-24-2007 06:41 AM
Gas light flashing with gas tank full qha000 W140 S-Class 1 03-29-2007 09:52 PM
Hallelujah, Gas Station to offer Terror Free Gas for all Liberals Jakarta Expat Off-Topic 11 01-26-2007 12:48 PM
gas smell, no signs of gas leak buckwyatt R/C107 SL/SLC Class 1 05-27-2006 08:53 PM
SL 320 gas cap, lots of pressure and gas on my shirt :-( e300d R129 SL Class 2 07-21-2004 08:36 AM
