Old 09-03-2007, 12:25 AM   #31 (permalink)
MIKEMAT's Avatar
Date registered: Mar 2007
Vehicle: B150 Sport pack
Mine for the first 2100 klm,consumption is about 9,2L/km using 95 octane unleaded fuel.
MIKEMAT is offline   Reply With Quote
Old 09-03-2007, 12:44 AM   #32 (permalink)
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Send a message via Yahoo to Mike Tee
Originally Posted by jkalpin
On the Canadian side I was getting 7.9 L/100 km. When I switched to miles it read 33.3 mpg.
7.9 is about 30 US MPG and 36 Imperial. So you were halfway between both, so it is hard to say which is which.
What speed were you driving at?
2008 Mercedes-Benz B 200
2005 smart fortwo cdi pulse cabriolet, loaded
1966 Peugeot 404 Coupé Injection
1989 Peugeot 405 DL, 366,000 km
Mike Tee is online now   Reply With Quote
Old 09-03-2007, 06:35 PM   #33 (permalink)
Date registered: Jun 2007
My mistake. I actually went back and checked the dash computer again and my mileage was actually 7.1 L/100 km (which translates to about 33.3 MPG). Throughout my trip between Toronto and NYC, I used 93 Octane Super Unleaded gas and my average speed was 120 kph in Canada and 70-75 mph in the USA. I also checked the web and the MPG computed by the dash computer is definitely using US Gallons. 7.1 L/100 km translates into 39 MPG using Imperial Gallons.
In the old days of traditional auto transmissions, they used to say that you optimized you gas mileage at 55-60 mph. With the new CVT transmission on the B-Class, I'm not sure this is the case anymore. I think the trick to good mileage with the B is not not speed related. I think you just need to keep a consistent speed and avoid any hard acceleration.
Jordan.
jkalpin is offline   Reply With Quote
Old 09-03-2007, 07:34 PM   #34 (permalink)
Mike Tee's Avatar
Wow, I am very impressed with your fuel consumption at that speed! Good job!
Old 09-04-2007, 06:03 AM   #35 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Actually there is a huge difference related to speed when using a MT on the B200.
I usually average 6.5 l @ 90 kph and 7.1 @ 105 and 7,7 @ 115 with a normal headwind.
A good headwind changes the #'s quite a bit. Cheers, Derek
Old 09-04-2007, 06:33 AM   #36 (permalink)
trout's Avatar
Date registered: Jul 2006
Vehicle: B Class 200SE
Jordan.
With the CVT transmission the best MPG I find is at 2000 revs ,also I do not use cruise control in hilly areas as it hunts up and down and ruins the MP
Present consumption = 8litres per 100 kilometres using Supermaket petrol
trout is offline   Reply With Quote
Old 09-05-2007, 12:52 PM   #37 (permalink)
Mike Tee's Avatar
Based on the above, I will be shooting for under 6 L/100 km when I drive the car to work. Maybe 5.8....that might be possible at a steady 85 with no wind.
Old 09-06-2007, 06:34 AM   #38 (permalink)
Well Mike that's quite an optimistic # to aim for. I've done that also but you make a lot of enemies when you look in your rear view mirror. More realistically, you will see around 6.7 l/100 km if you drive around 90 to 100.
Cheers, Derek
Old 09-06-2007, 11:02 AM   #39 (permalink)
Misfit's Avatar
Date registered: Nov 2005
Vehicle: '06 B200, '05 Smart
My best has been 6.1 on a several hour trip on a road with an 80Km/h speed limit with the cruise control set about 90
(non-turbo MT)
Misfit is offline   Reply With Quote
Old 09-07-2007, 12:32 AM   #40 (permalink)
Mike Tee's Avatar
Cheers, Derek
Well I get about 3.1-3.2 L/100 in my smart cruising at 85-90 on my commute, which is 13-14% less than the "official" highway rating. 6.7*.87 = 5.8
Also, the German Magazine Auto Bild tested a B 200 in 2005 and found that on their loop, the "minimum fuel consumption" was 5.8 L/100 km.
So I think I should be able to do it. We don't get much wind here!
560 SEL was 15 mpg, now 18 mpg dave850 W126 S,SE,SEC,SEL,SD,SDL Class 0 03-04-2006 11:17 AM
28 MPG homealone R171 SLK Class 16 07-04-2005 03:15 PM
G & trailer 9.8 mpg, G, triler, car 11.9 mpg? Kerr G-Class 11 03-08-2005 11:45 AM
mpg mike t G-Class 1 11-10-2002 04:23 AM
MPG Rodger W163 M-Class 7 11-18-2001 07:10 AM
