» Site Navigation
» Other Sites
Old 09-21-2006, 11:02 AM   #11 (permalink)
trout
trout's Avatar
Date registered: Jul 2006
Vehicle: B Class 200SE
Originally Posted by kdbcom
I usually have mine set to "S"
Thought I read somewhere that in S setting the system tailored itself to your driving habits
Excerpt from manual
[B]C Comfort
for a comfortable driving style
S Sport
for a sporty driving style
[/b]
The selected drive program (S/C) is shown in the multi-function display more.
Press program selector button repeatedly until the letter for the desired drive program appears in the multi-function display more.
Comfort mode C is characterised by the following:
The vehicle pulls away more gently in forward and reverse gears, unless the accelerator pedal is depressed fully.
Traction is increased. This improves the driving stability of the vehicle on slippery road surfaces, for example.
The transmission shifts up sooner. This means that the vehicle is driven at lower engine speeds and the wheels are less likely to spin.
Driving tips
Accelerator pedal position
Your style of driving influences how AUTOTRONIC shifts gear:
Little throttle: early upshifts
More throttle: late upshifts
Kickdown
Use kickdown for maximum acceleration:
Depress the accelerator pedal beyond the pressure point.
The transmission shifts to a lower gear depending on the engine speed.
Ease off on the accelerator pedal once the desired speed is reached.
The transmission shifts back up.
trout is offline   Reply With Quote
Old 09-21-2006, 12:49 PM   #12 (permalink)
kdbcom
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Section below reproduced courtsey of Baby Benz
This backs up my statement on the adaptive driving program in the S mode also there is a point raised regarding the downhill gradients & variable engine braking
Apologies for the long gap down to the extract from Baby-Benz it comes a fair way down the page
To control the AUTOTRONIC functions Mercedes-Benz has developed a powerful microprocessor which is integrated into the transmission. It is linked to the electronic network in the new A-Class via a data bus and also processes the signals from various transmission sensors. These include:
Speed sensors for the primary and secondary discs, as well as the output shaft
Temperature sensor for the transmission oil
Pressure sensor for the secondary discs
Sensor for the selector lever position
The electronic control unit uses the numerous sensor data to calculate the current vehicle speed, the actual torque at the transmission’s input shaft, the flow rates required for the electro-hydraulic transmission control system and the gearshift strategy, i.e. selection of the most suitable ratio and the action of the torque converter lockup clutch. Other parameters relevant to the shift strategy are also included in the calculation process. The transmission control system is also able to take into account the vehicle load, uphill or downhill gradients, the longitudinal and lateral acceleration of the A-Class and the individual style of driving, for example. In this way AUTOTRONIC selects the most suitable ratio for every operating condition and driver requirement.
This is referenced to A class but presumably the B class should be the same
the engine speed is lower at constant speed
The most suitable ratio is always selected on downhill gradients
There is a variable engine braking effect on downhill gradients
Acceleration:
The ratios are changed without interrupting tractive power
The engine reaches its rated output more rapidly
Flexibility:
The engine always performs at its best possible operating point
These advantages ensure a considerable improvement in driving pleasure and performance.
Choice of three shift programs
The new AUTOTRONIC is just as easy to operate as a conventional Mercedes automatic transmission. The selector lever positions "P", "R", "N" and "D" correspond to the familiar shift gate. Pressing a button enables the driver to choose between two shift programs: "C" for Comfort and "S" for Sport.
In the Comfort program the transmission keeps the engine speed at the lowest possible level, so that for instance the A-Class accelerates gently and uses less fuel. In the Sport program AUTOTRONIC becomes adaptive: it automatically recognises the individual style of driving and adapts the gearshift strategy accordingly. If the driver has a more sporty driving style, for example, the transmission makes higher performance reserves available by raising the engine speed, while in the case of a more relaxed, comfort-oriented style the engine speed is reduced
kdbcom is online now   Reply With Quote
Old 09-21-2006, 01:11 PM   #13 (permalink)
trout
trout's Avatar
Most interesting will try 1000 miles in S and compare consumption
Many thanks
Old 09-22-2006, 03:40 PM   #14 (permalink)
Diezel
L/100km
Additional remarks:
I guess it's a lot about driving style; my wife had the car for a 74 km trip the other day, doing 7.6 l/100km. I tend to think of an egg between right foot and the pedal when going downhill and when accellerating following others in the lane. Still I enjoy the good fun the high torque gives when cars behind disappear with a surprise once in a while. Still going from Drammen to Oslo (40 km) the other day, I made all-time-low at 4.1 l/100km. Hope to post a picture next time )
Diezel is offline   Reply With Quote
Old 09-23-2006, 03:13 AM   #15 (permalink)
Ikelos
Date registered: Aug 2006
Vehicle: B 170se with sports pack.
Send a message via Skype™ to Ikelos
Pity i can not get my head round all this litres and kilometres, give me the old gallons and miles any day....
Ikelos is offline   Reply With Quote
Old 09-23-2006, 03:38 AM   #16 (permalink)
kdbcom
kdbcom's Avatar
Here here or should it be hear hear
MPG please
Old 06-06-2007, 08:43 AM   #17 (permalink)
Derek Lecours
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Here in Canada we only have the B200 & B200 Turbo, both are petrol . I baby my B200 and average 6.7 to 7.1 /100 liters. the moment you accelerate past 90 kph you notice the increase in fuel used right away
Old 06-07-2007, 09:33 AM   #18 (permalink)
A.N.
A.N.'s Avatar
Date registered: Apr 2007
Vehicle: 06 White B200T
I took my B200T into BC on the weekend (2000 kms round trip) on the flats of Alberta I got about 8.3 L/100 km (@ 125-130 kph), in the mountains I was getting (7.9 L/100 km) (@ 80 -100 kph). That turbo is great in the hills, specially when you're on mountain logging roads by accident (oops).
Anthony
A.N. is offline   Reply With Quote
Old 06-07-2007, 11:20 AM   #19 (permalink)
kdbcom
kdbcom's Avatar
And how about oil consumption it would appear that if you fill to just under the maximum (they state you should never exceed the max, due to damage to oil seals) I've noticed that the oil seems to go to the halfway mark fairly quickly (650 mile approx) but to go near the lower mark seems to take about 1500-2000 miles
I did notice after my last service that the dealer had only filled up to the halfway mark could this be the reason ??
I refer to "marks" being the indicators on the dipstick & not the electronic (within instrument cluster) method as I don't really trust the electronic sensing method.
£10 worth of oil (1 litre) for 650 miles does seem a bit expensive.
Old 08-26-2007, 11:02 PM   #20 (permalink)
Mike Tee
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Send a message via Yahoo to Mike Tee
I would expect the oil consumption to be below 0.1 L/1000 km....I know they say up to 0.8 is "normal".
My smart cdi goes 10,000 km between services/oil changes, and I never have to top it up; in fact not more than 0.3 L of oil is consumed in 10,000 km.
2008 Mercedes-Benz B 200
2005 smart fortwo cdi pulse cabriolet, loaded
1966 Peugeot 404 Coupé Injection
1989 Peugeot 405 DL, 366,000 km
Mike Tee is offline   Reply With Quote
560 SEL was 15 mpg, now 18 mpg dave850 W126 S,SE,SEC,SEL,SD,SDL Class 0 03-04-2006 11:17 AM
28 MPG homealone R171 SLK Class 16 07-04-2005 03:15 PM
G & trailer 9.8 mpg, G, triler, car 11.9 mpg? Kerr G-Class 11 03-08-2005 11:45 AM
mpg mike t G-Class 1 11-10-2002 04:23 AM
MPG Rodger W163 M-Class 7 11-18-2001 07:10 AM
