Old 06-07-2006, 08:36 AM   #1 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Easy Vario Seat System info required urgently
Hi
Has anyone out there got th Easy -Vario Seat option on their B class.
If so can you give me any info about removing the front passenger seat.
Presumably you have to remove the big red plug from the seat when you remove it if so do they supply you with a dummy plug to put in its place ?
If so is there a part number on it ?
Do you get any warning messages about the srs or belt systems come up on the dash display ?
This information is urgently required as I need to be able to remove the Mercedes front passenger seat to fit a non standard mobility seat.
kdbcom is offline   Reply With Quote
Old 06-20-2006, 11:11 AM   #2 (permalink)
Easy Vario
kdbcom, try this link for manuals. it's in english in there as well:
http://www4.mercedes-benz.com/d/cars...iebsanleitung/
Good luck
Diezel is offline   Reply With Quote
