Old 05-26-2006, 04:02 AM   #1 (permalink)
retrofit aircondition in B-Class
Hallo there everybody.Is it possible to retrofit aircondition(code 580) in a B-Class?
Savvas is offline   Reply With Quote
Old 06-12-2006, 09:27 AM   #2 (permalink)
kdbcom's Avatar
Date registered: Feb 2006
Vehicle: B200 CDI SE
Looked into the posibility of retro fitting air con on a Renault Scenic I had a couple of years ago it was a no no. Think you may find the same problem with the b class
kdbcom is offline   Reply With Quote
Old 08-05-2006, 08:01 AM   #3 (permalink)
gsp1's Avatar
Date registered: Aug 2006
Vehicle: B150+Sports
I think, because i had the same question about audio 20 after put audio 5, that everything that it has to do with panel layout its not possible to change afterwards...
gsp1 is offline   Reply With Quote
Old 08-18-2006, 10:41 PM   #4 (permalink)
n0alpha's Avatar
Date registered: Mar 2004
Vehicle: Silver 1994 C280
It certainly is possible (my friend and I retrofitted it into his 1989 Honda Civic), but then again it was difficult and time consuming. We used the A/C parts from an Acura Integra (very similar design because Honda and Acura are the same company).
In short, your mileage may vary.
Silver 1994 C280
125,000 miles
Mercedes: Time-tested engineering, timeless styling.
n0alpha is offline   Reply With Quote
