Balance Shaft Failure, starting what MY or engine num is it fixed? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-23-2010, 12:10 PM Thread Starter
MBS430's Avatar
Date registered: Oct 2005
Vehicle: S550, S430
Question Balance Shaft Failure, starting what MY or engine num is it fixed?
the balance Balance Shaft Failure that is discussed on
ML350 3.5L Balance Shaft Failure - PeachParts Mercedes ShopForum
and
http://www.benzworld.org/forums/w164...t-failure.html
is indicated with CEL for
P1208 INTAKE RIGHT SIDE ADJUSTER INTAKE
P1200 RIGHT SIDE EXHAUST ADJUSTER.
There is a speculation that the earlier run of production motors had a balance shaft gear that was too soft, and in turn the chain would wear it out prematurely. The new updated balance shaft gear has not shown any issues.
The attached service bulletin indicated W221 (S550) is affected.
If one get this issue, the repair requires engine rebuilt and can be ~$7,000 at dealer.
do you know starting what MY or engine number does MB uses the new updated balance shaft?
thanks in advance for anyone who can shed some light.
MBS430 is offline
post #2 of 8 (permalink) Old 09-23-2010, 12:33 PM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 212 Post(s)
“Applicable Models (Not Applicable to Model 164.156, 204 or 216.386): Equipped with M272 Engine Up to Serial No. 2729..30 468993 or M273 Engine Up to Serial No. 2739..30 088611. The material for the balance shaft sprocket and the timing chain guide wheel (idler) was modified on engines past the serial numbers listed above.”
konigstiger is offline
post #3 of 8 (permalink) Old 09-23-2010, 01:15 PM Thread Starter
MBS430's Avatar
Vehicle: S550, S430
thanks for the prompt response konigstiger!
can you advise:
- what W221.186 & W221.171 means?
- how do we find out whether an S550 has engine M272 or M273?
thank you
MBS430 is offline
post #4 of 8 (permalink) Old 09-23-2010, 06:21 PM Thread Starter
MBS430's Avatar
Vehicle: S550, S430
in US:
W221.171 = S550 LWB
W221.186 = S550 4Matic LWB
M273 engine is a V8 and M272 is V6.
so for S550 in US, to avoid this issue, try to look for engine serial no beyond 2739..30 088611.
anyone has any idea what MY will that be?
MBS430 is offline
post #5 of 8 (permalink) Old 03-15-2011, 01:36 PM
Date registered: Mar 2011
in US:
W221.171 = S550 LWB
that is not the vin number we're looking for right? if not, wheres that number located at on the vehicle
showtime1k is offline
post #6 of 8 (permalink) Old 03-15-2011, 03:19 PM
Vehicle: '71 Pinto
Quoted: 212 Post(s)
Click here ?????? enter VIN – datacard (upper right) – engine # if you cannot pull datacard PM your VIN and I will check if vehicle is within engine # range.
post #7 of 8 (permalink) Old 03-15-2011, 08:02 PM
eric242340's Avatar
Quoted: 307 Post(s)
The engine number is on the front of the left hand cam cover.
ERIC.
eric242340 is offline
post #8 of 8 (permalink) Old 03-16-2011, 11:47 AM
dont have a vin yet, but want to know what to look for, im currently in the market for an s550. dont know whats detailed in a job like that(replacing the gear), but has anyone done it them self. or have the replacement service sheet procedure. jus called dealer, the job is $5000 from what the dealer said, would have to consider that in the price i purchase for if its one of those models.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
    ML350 3.5L Balance Shaft Failure azinn W164 M-Class 217 Yesterday 03:32 AM
    Has anyone ever had to replace their balance shaft? Achped W203 C-Class 531 01-06-2016 04:41 PM
    ML350 3.5L Balance Shaft Failure azinn W163 M-Class 0 02-22-2010 01:52 PM
    Girlfriends 2006 ML350 CPO - Balance Shaft Issue? 07ML350Mass W164 M-Class 0 06-19-2009 08:24 AM
    '95 E300D: Cam Shaft Failure! RotaryMan W124 E,CE,D,TD Class 5 12-08-2006 05:46 PM
