» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W221 S-Class
Old 09-29-2009, 06:34 AM   #1 (permalink)
Date registered: Apr 2007
S550 Oil Change Interval Changed
Does anybody know why the '07 had a 13K oil change interval but the '09 has a 10K interval?
2009 S550 4Matic
1993 300SD
MercedesCarNut is offline   Reply With Quote
Old 09-29-2009, 07:04 AM   #2 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
I don't know but could it be because of the simplified service program where only two options exist. One program at 10 000 miles or a year, then every 20 000 miles or two years. The other one at first 20 000 miles or 2 years and then every 20 000 miles or two years.
Diesel Benz is online now   Reply With Quote
Old 09-29-2009, 07:30 AM   #3 (permalink)
eric242340's Avatar
Vehicle: S320 and Zotye 1.3
Send a message via Skype™ to eric242340
Simply put, 13K is too long on this engine, 10k is better. In China we are using DAS to shorten the service to 8K as these engines need more frequent oil service.
The balance shaft gear in the center of the engine will develop abnormal wear if the oil is not changed regularly and this could, at worst, result in engine replacement and at best an engine rebuild.
I do not wish to worry you here and as long as you change the oil on a regular basis, all should be ok.
ERIC.
A lie gets halfway around the world before the truth has a chance to get its pants on.
Winston Churchill
eric242340 is offline   Reply With Quote
Old 09-29-2009, 07:55 AM   #4 (permalink)
That makes sense. I do remember reading something about that before.
Old 09-29-2009, 08:44 AM   #5 (permalink)
But wasn't the service period and service program changed for all models?
Old 09-29-2009, 08:53 AM   #6 (permalink)
eric242340's Avatar
You are in Europe DB so you tell us what the policy on this change was in Europe. But here it was not changed for all models.
Oil change interval Avantgarde E55 W211 E55 AMG, E63 AMG 5 05-18-2007 06:10 AM
Oil Change Interval Marsden General Mercedes-Benz 32 02-20-2006 02:47 PM
oil change interval mbeclass W126 S,SE,SEC,SEL,SD,SDL Class 8 11-03-2004 07:30 AM
oil change interval? mikeyCLK Detailing and Car Care 7 02-09-2004 09:46 PM
oil change interval mikeyCLK W208 CLK Class 11 01-06-2003 07:57 PM
