removing door panel/door tray - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-19-2009, 05:29 PM Thread Starter
Date registered: Sep 2008
Vehicle: 2008 S550 4Matic (mine), 2008 C300 4Matic (wife's)
So you may have seen my post below. I lost a stone from a piece of jewelry; turns out that it fell thru a small area inside of the card/license holder in the driver side door panel. If you look on an angle, you can see the lights for the door shining thru the slot.
How can I remove the change tray in the door panel so I can get it back?
If I can't how do I remove the interior driver side door panel?
JaredC79 is offline
post #2 of 2 (permalink) Old 08-19-2009, 10:22 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
If I can follow which parts you want to remove, I'm afraid it is only possible once the door panel has been removed.
Removing the door panel includes several steps, you'd better find the workshop instructions for this task. Either subscribe for WIS access or request a print from a member who already has access.
Hopefully the piece has not escaped via water drain holes (you might want to block those temporarily).
Diesel Benz is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
    removing door panel help please mercme W203 C-Class 1 11-07-2009 05:11 PM
    removing door panel help !!!!!!!!!! amgstyle R170 SLK-Class 11 10-13-2008 02:42 PM
    Since removing the door panel mckellyb W126 S,SE,SEC,SEL,SD,SDL Class 5 09-29-2007 02:29 PM
    Removing Door Panel? dunga W210 E-Class 2 08-31-2004 09:12 PM
    Removing Door Panel Guest (MBNZ) W201 190-Class 2 02-16-2002 03:20 PM
