» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W221 S-Class
Old 07-18-2009, 10:39 PM   #1 (permalink)
Date registered: Feb 2007
please help check engine light !
hi GUYS I have a 07 s550 it's been setting for 4 months I know thats not good but thats the story. the battery was down the remote would not unlock the doors but the car started fine then I found out the car has 2 batterys lol ,, ok i drove it it went down te road like a new benz then I parked it it sat for 3 hours dam the thing will not unlock agine ! Now I stared the auto agine ran it for 30 mins. shut it off the re started it now the check engine light is on??? first ? wheres the battery in the trunk i can't find it ?
2nd ? is there a way to reset the check light like a gm? please help thanks...
frankmarks07 is offline   Reply With Quote
Old 07-19-2009, 12:12 AM   #2 (permalink)
eric242340's Avatar
Vehicle: S320 and Zotye 1.3
Send a message via Skype™ to eric242340
The trunk battery is behind the passengers seat to the right of the trunk but you will have to remove all the trim to get to it. To reset the fault codes is normally done with a code reader but you may try disconnecting both batteries for half a hour.
ERIC.
A lie gets halfway around the world before the truth has a chance to get its pants on.
Winston Churchill
eric242340 is offline   Reply With Quote
Old 07-19-2009, 12:19 AM   #3 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
Originally Posted by frankmarks07 View Post
wheres the battery in the truck i can't find it ?
Be gentle with the car and don't call it a truck. The rear battery is behind the centre panel at the trunk.
You should figure out the reason for the check engine light first, could be as simple as a loose fuel tank cap but it could be something more serious too and could harm your engine.
Edited: I must have missed Eric's reply, perhaps I was searching for the photo too long and his response was not there when I started writing mine, Eric already covered the topic.
Diesel Benz is online now   Reply With Quote
Old 07-19-2009, 08:58 AM   #4 (permalink)
dbs600's Avatar
Date registered: Jul 2005
Vehicle: 1994 S500 Sedan
wow. i didnt know that the battery was placed right up against the rear of the right rear passenger seat. in the 140 its in the trunk at the far right rear corner of the car. i wonder how much emf the battery emits when the car is on... not good.
dbs600 is offline   Reply With Quote
Old 07-19-2009, 09:17 AM   #5 (permalink)
thanks i fixed it it's a trunk lol.
thanks lol....
Old 07-19-2009, 09:22 AM   #6 (permalink)
Thanks All I'm just going to take it to Mercedes service it's still under warrinty I called them last night , thanks for all the help .. dam the rear battery looks like it's in a unsafe place ! my 99 and 2000 s class was in the side or the trunk . I don't like this My kids sit right there !!
Old 07-19-2009, 09:42 AM   #7 (permalink)
The W210 and some other models have the battery below the rear seat bench. The battery is not dangerous, specifically if nothing hits it. Below the rear seat bench or behind the seat it would be safe in an accident.
EMF from the battery? Think of the wiring from the front to the rear, even that is nothing compared to all the electronics in the car and even all that can be taken care of.
I would complain about the battery service, it would be easier to reach if it was below the rear seat or at the trunk floor. Then again, service like the topic of the thread should not be needed often.
Old 07-19-2009, 11:13 AM   #8 (permalink)
update ! I think it was the fuel cap redone it ,,drove the car to autozone to check the codes theres no codes now the light whent off & the rear battery is holding a charge ? I hope this fixes my car ,,,,I live 80 miles from the Mercedes service center I din't want to drive it there with a light on ,,,,Thanks to all of You ,For Your HELP!!
2002 c 230 check engine light and srs light upstaterider2003 General Mercedes-Benz 4 08-04-2008 07:35 AM
1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 09:19 PM
How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
check engine light & flashing fuel guage light pd99sl500 R129 SL Class 7 02-27-2005 04:31 PM
Help Please!!! Check Engine Light...Empty Fuel Light Flashing mJstk01 R170 SLK Class 6 05-18-2003 10:53 AM
