rear camera and trunk closer retrofitted. Pics here
I recently did a rear view camera install and trunk closer on a 2007 s550. Here are some of the pictures during the install.
2003 c320 Sedan - Completely updated to 2005 spec with all euro and usa options
2002 s500 Sedan - Completely updated to 2006 spec with all USA options and some euro options.
I have been looking to do this on my 07 S550 4Matic AMG... all packages but this one.
Thanks in advance for the help.
Obsidian Black Metallic / Red Leather
Comfort, Lighting, Premium Package
Heating Package + Airscarf
Sport Suspension, MHI Installed
Entertainment Package + Nav
Komfort Variodach Modul (Piecha)
Brabus Style Puddle Lights
Euro Clear Side Markers
Kleyman 1 - Brake Flasher
LED License plate + Dome Bulbs
18 x 8.5 P225/40 - front
18 x 9.5 P255/35 - rear
Pirelli PZero Nero
Custom Flipout 7" LCD
w/Rear Camera, Front Nightvision Camera, TV tuner
__________
No Regrets!
Why? For those guys like sunman, miroj, mbenznl, by default nothing is impossible. A different thing if the referred tasks are possible for me and you. I thought the photos already showed well how much work is needed to feed all the cables properly etc. And a factory visit for DAS version coding (SW updates?) would be needed as I don't have star diag at home (but for an enthusiast, DIY for the rest could be fine).
Still looking for a solution for the rear camera install.
Can anyone help with a part number list and costs?
Thanks.
for the camera i believe it works out to be like $1500 installed for the aftermarket solution (camera but no park-assist). if you want to do the factory camera/park assist retrofit its more like $3500 installed.
i havent priced a trunk closer for the S550 but i did one on an R class a few months back and i think it was like $3100. the biggest issue was that there is no harness available (it comes as part of the main vehicle harness) so tehre is no part or part #. a custom harness and connectors had to be fabricated to make the whole thing work. im not sure if it would be the same for the new S class but if your really interested i could find out.
Thanks for the info. I am interested in the factory camera+park assist as Sunman did on his S550. There is supposed to be a seperate wire run from the back camera to a module that plugs into the command at the front of the car. That is what i was told by a service rep.
Already have the trunk closer installed
yes, a 75 ohm video cable needs to be run from the park-assist module in the back to the AGW at the front. fortunately all the parts to do that are readily available. also main connector to the park assist module is not present if you didnt order it and has to be built as well.
