Originally Posted by minimaybach are you referring to the audible warning signal during parking? or the audible sound you hear when you are approaching a vehicle too quickly with the radar sensors??
What I want is an earlier warning that I'm approaching my garage wall or some similar situation. |
This is from the car manual:
Collision warning
Park Assist can detect obstacles from a
considerable distance. If you drive in reverse
towards an obstacle, you will hear a
warning tone. You must then brake in order
to avoid a collision. The warning tone
for a collision will not sound when the vehicle
is at a standstill very close to the obstacle.
In this case, you will hear a
corresponding tone for the warning indicator
in the rear area.
The normal operation is not different on Park Assist from that of Parktronic. The early warning sound works from a distance of 11 metres. I don't think it helps in your case though, you probably are approaching the garage wall at a speed where the early warning does not come on and once you are at a distance where the led indicators turn on, the operation of both systems is very similar.
It might be better if you were able to choose if the audible indication came on already "from the first led" or only from the first red led as now. I guess there are (at least) two reasons why MB is generally not supporting options like this: so many drivers get confused with the settings, adjust them wrong to their preferences and then the drivers are not happy, neither dealers from all those complaints. The other one obviously is IPR.
