Campaign 2006120006 DEC06 – Replace ABC high-pressure line; inspect coolant hose and replace if necessary.
221.176 VIN range: A022143 to A030502, approximately 33 vehicles affected *
On affected vehicles the geometry of the ABC high pressure line may not meet specifications. This can cause the ABC high pressure line to be in contact with the engine coolant hose. The dealer will replace the ABC high pressure line with a modified version and also check and replace the engine coolant hose if necessary.
* Notes:
(1) Service Campaigns are done on a voluntary basis by MBUSA, but are also monitored by the Government. Repairs are performed by dealer when vehicle is in for service work.
(2) Every vehicle in the VIN range may not be included in the campaign. Have your dealer to check VMI to confirm.
'06 CLS500: Iridium Silver/Black leather/ High Gloss Laurel wood trim; Electronic trunk closer; SIRIUS; VCS; 318 Trim pkg (wood/leather steering wheel & wood shift knob); 326 Premium pkg (multicontour/active ventilated seats, logic 7; MP3 6-disc changer; COMAND DVD nav; power rear sunshade); built 8/05, delivered 10/05.
