Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W221 S-Class
Old 12-25-2006, 08:51 AM   #1 (permalink)
Date registered: Aug 2006
Installing Satellite
I'm considering putting xm satellite into my s550. Ideally, I would like to put the antennae on the dash in front of the steering wheel, close to the windshield. Anyone have any experience with this? Does the windshield have any metal in it that would obstruct signals? Sirius satellite is not yet an option in Canada, and since I therefore need to basically start from scratch, I'm looking for the best and cleanest way to do the install. Any advice would be appreciated. Happy holidays to everyone!!!
strolee is offline   Reply With Quote
Old 12-25-2006, 10:52 AM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
The factory satellite receiver is installed to the trunk, left side. Wouldn't it be easier to wire the sat antenna to the back too, perhaps exactly as in the factory installation?
The windshield of an S550 is blocking radio signals (IR shielding). There is a small hole in the centre of the windshield, one at the bottom, one at the top area (see user's manual) but I would assume those being too small for good satellite reception.
Diesel Benz is offline   Reply With Quote
Old 12-25-2006, 09:11 PM   #3 (permalink)
Tony_K's Avatar
Date registered: May 2005
Vehicle: 95 E320 (Sold!), 06 ML350, 03 S430, 00 Pontiac Formula WS6
I'm in a W220 not 221, but when I did my Sirius install, I tried inside as you suggest and it didn't work. I ran the antenna wiring behind the dash, out through the cableway in the passenger door up into the channel along the roof pillar behind the weather modling and I mounted on the passenger side roof right at the corner above the windshield. These installs are hard on these cars, I've done it on my S, my wife's M and on my old E and they are so well built and tight, there is no place to really pass wires (unlike when I did an XM install in my Forumula). Good luck....
http://www.olphoto.net
"From out of no where a Mercedes Benz; came cruising up and whipped right in"
Blake Shelton, "Some Beach"
Tony_K is offline   Reply With Quote
Satellite Radio MacDubois W126 S,SE,SEC,SEL,SD,SDL Class 3 08-17-2006 03:42 PM
Installing Satellite Radio andrewblong R170 SLK Class 14 12-26-2005 03:15 PM
Installing Satellite Radio dh1760 W209 New CLK Class 4 11-19-2005 12:04 PM
Satellite Radio My04230k W203 C-Class 15 12-01-2004 08:16 PM
XM Satellite Radio Guest (MBNZ) Audio & Telematics Forum 5 03-19-2002 03:21 PM
